Csanderson0628
Petal issue
Csanderson0628
I have a wheel house tractor with a 16hp kohler engine. Model k341as. My tractor has been setting for a month and went go to start it and my pedal is completely stuck down. Will not move even a little. Any ideas?
Thanks
Achto
:WRS:
Is the parking brake lever set by chance??
Edited by Achto
Csanderson0628
No it's not.
Achto
Ok, next questions - Hydro or gear shift? What model is it?
953 nut
:WRS:
Unfortunately the 3/4" shaft and brake pedal are both steel and have no bushings. They tend to rust together when setting and the best solution is to jack up the left side, heat the pedal and melt some  paraffin wax into the gap, then move it gently back and forth. Once it is moving well remove it and use some never seize.
Csanderson0628
Hydro system. Model k341as.
thank you. I will give that a try and let you know.
The Tuul Crib
I actually drilled out the whole on the pedal and tapped a quarter 28 size thread and put a grease fitting on it
Csanderson0628
Thanks everyone, it's now like it should be.
