Csanderson0628 0 #1 Posted October 27, 2018 I have a wheel house tractor with a 16hp kohler engine. Model k341as. My tractor has been setting for a month and went go to start it and my pedal is completely stuck down. Will not move even a little. Any ideas? Thanks Share this post Link to post Share on other sites
Achto 31,020 #2 Posted October 27, 2018 (edited) Is the parking brake lever set by chance?? Edited October 27, 2018 by Achto 1 Share this post Link to post Share on other sites
Csanderson0628 0 #3 Posted October 27, 2018 No it's not. Share this post Link to post Share on other sites
Achto 31,020 #4 Posted October 27, 2018 Ok, next questions - Hydro or gear shift? What model is it? Share this post Link to post Share on other sites
953 nut 64,140 #5 Posted October 27, 2018 Unfortunately the 3/4" shaft and brake pedal are both steel and have no bushings. They tend to rust together when setting and the best solution is to jack up the left side, heat the pedal and melt some paraffin wax into the gap, then move it gently back and forth. Once it is moving well remove it and use some never seize. 1 Share this post Link to post Share on other sites
Csanderson0628 0 #6 Posted October 27, 2018 Hydro system. Model k341as. thank you. I will give that a try and let you know. Share this post Link to post Share on other sites
The Tuul Crib 7,340 #7 Posted October 28, 2018 49 minutes ago, Csanderson0628 said: Hydro system. Model k341as. thank you. I will give that a try and let you know. I actually drilled out the whole on the pedal and tapped a quarter 28 size thread and put a grease fitting on it 1 Share this post Link to post Share on other sites
Csanderson0628 0 #8 Posted October 28, 2018 Thanks everyone, it's now like it should be. Share this post Link to post Share on other sites
