Lane Ranger 11,681 #1 Posted October 27, 2018 It still amazes me how many different key switches that WheelHorse andToro used on their various model tractors! I learn something new with eachswitch! 5 Share this post Link to post Share on other sites
Achto 30,226 #2 Posted October 27, 2018 When it comes down to the Indak switches. I usually buy a the switch to fit my needs (magneto or coil ignition) then just remove the wires from the plug and reconfigure them to work with the switch if, need be. 1 5 Share this post Link to post Share on other sites
Lane Ranger 11,681 #3 Posted October 28, 2018 You are a better mechanic than me Dan! 1 2 Share this post Link to post Share on other sites
Achto 30,226 #4 Posted October 28, 2018 11 minutes ago, Lane Ranger said: You are a better mechanic than me Dan! Or a cheap a--, depends on how you look at it I guess. 3 3 Share this post Link to post Share on other sites
rjg854 12,650 #5 Posted October 28, 2018 Frugal is GOOD 4 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #6 Posted October 28, 2018 No I think it’s called saving up for the next tractor! 2 1 2 Share this post Link to post Share on other sites
Lane Ranger 11,681 #7 Posted October 28, 2018 You are a better mechanic than me Dan! ihate all those electricalconnectors! 1 Share this post Link to post Share on other sites
squonk 44,922 #8 Posted October 28, 2018 9 hours ago, Lane Ranger said: You are a better mechanic than me Dan! ihate all those electricalconnectors! Here you go Lane! 2 1 Share this post Link to post Share on other sites
Retired Wrencher 6,182 #9 Posted October 28, 2018 (edited) Lane I remember one of my first was a 312A. It had a funky foot pedal switch that had to fitted just right to start the tractor. It was a great tractor other than the safety switches. Edited October 28, 2018 by Retierd Wrencher 1 Share this post Link to post Share on other sites
Lane Ranger 11,681 #10 Posted October 28, 2018 Here is a list of the various ways Indak makes its three position key switches from their website, they have 3, 4, 5 and some 6 lugs on the switches. Makes for a lot of permutations folks! 3 Position Key Switches (Stamped Keys) Part Number Switch Type Bushing Type: Terminal Type Connector Type PE # Circuits Made: Notes Thread Length Pos. 1 Pos. 2 Pos. 3 451A Bat.Ign. .9/16-24 .310″ LUG(3) LUG(8-32) None B+I B+I+S 2 B451A Bat.Ign. 9/16-24 .310″ PE(3) 2962510 None B+I B+I+S 2 C451A Bat.Ign. 9/16-24 .310″ PE(5) PE56 None B+I B+I+S 2,9 F451A Magneto 9/16-24 .310″ LUG(2) LUG(8-32) M+G None S+G 1,2 G451A Special 9/16-24 .310″ PE(4) 2962510 D+G/None None/B+C None/B+C+S 1,2,9 K451A Magneto 5/8-32 .406″ LUG(3) LUG(8-32) M+G None B+S 1,2 N451A Bat.Ign. 9/16-24 .310″ LUG(3) LUG(8-32) None B+I B+I+S 2 T451A Magneto 5/8-32 .406″ LUG(4) LUG(8-32) M+A None B+S 2 463A Bat. Ign. 9/16-24 .310″ LUG(3) LUG(10-32) None B+I B+I+S 2 D463A Magneto 9/16-24 .310″ PE(5) 2973422 G+M+A B+A+R B+S 1,2 E463A Bat. Ign. 9/16-24 .310″ PE(5) 2973422 None B+A/X+Y B+S/X+Y 2 G463A Magneto 5/8-32 .406″ PE(6) 2973422 G+M+A B+A+R B+S 1,2 J463A Bat. Ign. 9/16-24 .310″ PE(5) 2973422 None B+R+I+A B+R+I+S 2 K463A Magneto 9/16-24 .310″ PE(3) PE 56 M+G None B+S 1,2 L463A Magneto 5/8-32 .406″ PE(5) 2973422 G+M B+L B+S 2 M463A Magneto 5/8-32 .406″ LUG(4) LUG(8-32 & 10-32) M+G B+A B+S 1,2 P463A Magneto 5/8-32 .406″ L(2) PE(3) LUG(10-32) PE 56 G+M+A B+A+R B+S 2 R463A Magneto 9/16-24 .310″ LUG(3) LUG(8-32) M+G None B+S 1,2 S463A Magneto 5/8-32 .406″ L(2) PE(1) LUG(10-32) PE 56 M+G None B+S 1,2 U463A Bat. Ign. 9/16-24 .310″ PE(5) 2973422 None B+I+A/None B+I+S/X+G 1,2 V463A Magneto 5/8-32 .406″ PE(3) PE 56 M+G None B+S 1,2 W463A Magneto 5/8-32 .406″ PE(5) 2973422 M+G B+L B+S 1,2 Y463A Magneto 5/8-32 .406″ L(2) PE(2) LUG(10-32) PE 56 M+G None B+S 1,2 Z463A Diesel 9/16-24 .310″ LUG(4) LUG(8-32 & 10-32) None B+I+A B+I+H 2,3 3B463A Bat. Ign. 5/8-32 .406″ PE(5) 2973422 None B+R+I+A B+R+I+S 2 3C463A Magneto 5/8-32 .406″ L(2) PE(4) LUG(10-32) PE 56 G+M+A B+A+R B+S 1,2 3E463A Special 9/16-24 .310″ LUG(5) LUG(8-32) D+G/None D+O/B+C None/B+C+S 1,2,6 3G463A Magneto 5/8-32 .406″ PE(4) 2962510 G+M None B+S 1,2 3H463A Magneto 5/8-32 .406″ PE(5) 2973422 G+M B+L B+L+S 1,2 3J463A Bat. Ign. 5/8-32 .406″ PE(4) 2973422 None B+I+A B+I+S 2 3K463A Diesel 9/16-24 .310″ LUG(4) LUG(8-32 & 10-32) None B+I+A B+I+H 2 3N463A Bat. Ign. 9/16-24 .310″ PE(6) 2973422 None B+I+A/X+Y B+I+S 2 3S463A Magneto 9/16-24 .310″ PE(6) 2973422 & 2962448 None/M+G B+A/None B+A/S1+S2 2 3T463A Diesel 9/16-24 .310″ LUG(4) LUG(8-32 & 10-32) None B+I+A B+I+H 2,8 3U463A Special 5/8-32 .406″ PE(5) 2973422 None B+A/X+Y B+S/X+Y 2 3W463A Magneto 9/16-24 .310″ PE(6) 2973422 G+M+A B+A+R B+S 1,2 3Y463A Magneto 5/8-32 .406″ PE(5) 2973422 G+M B+L B+L+S 1,2 3Z463A Magneto 9/16-24 .310″ PE(5) 2973422 G+M B+L B+L+S 1,2 4C463A Magneto 5/8-32 .406″ PE(3) 2962510 G+M None B+S 1,2 4F463A Magneto 5/8-32 .406″ PE(6) 2973422 & 2962448 G+M+A B+L+A B+L+S 1,2 4G463A Magneto 5/8-32 .406″ PE(5) 2973422 G+M B+L B+L+S 1,2 4J463A Magneto 9/16-24 .310″ PE(6) 2973422 G+M+A B+A+R B+S 1,2,4,6 4M463A Bat. Ign. 5/8-32 .406″ PE(6) 2973422 None B+I+A/X+Y B+I+S 2 4N463A Special 9/16-24 .310″ LUG(5) LUG(8-32) D+G/None D+O/B+C None/B+C+S 1,2,7 4P463A Bat. Ign. 9/16-24 .310″ PE(6) 2973422 & 2962448 None B+I+A/X+Y B+I+S 2,7 4Q463A Magneto 5/8-32 .406″ PE(6) 2973422 & 2962448 G+M+A B+L+A B+L+S 2 4S463A Magneto 5/8-32 .406″ PE(6) 2973422 & 2962448 G+M+A B+L+A B+L+S 1,2,5 Notes: 1. Case is grounded. 2. Spring return from position “3” to position “2”. 3. 6 Amp circuit breaker. 4. All terminals except “ground” terminal are copper. 5. Terminals “B” & “A” are brass, tin plated. 6. Drain holes in two places. 7. Drain holes in three places. 8. 10 Amp circuit breaker. 9. Drain hole in one place. 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #11 Posted October 28, 2018 On the 753 and 552 of mine they are running on off switches from snowblower. The 753 has a 1958 k160 bolens engine running the k161 magneto and bearing cover. The 552 has a h70 on it Share this post Link to post Share on other sites
Warning:Unsupervised 83 #12 Posted May 23, 2023 (edited) Anyone know what differs on the Indak 6 pole switches with part #103991 that have (Number 3) on the Ground pole vs (Letter G)?? Same part numbers, look the same but has that #3? This diagram shows #3 not the more common G switch? Sorry tried to just paste a pic here but Ebay didnt allow me to copy it. https://www.ebay.com/itm/270809011090?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=WB0Eoua4S1m&sssrc=2349624&ssuid=jdKlBQXkQjq&var=&widget_ver=artemis&media=COPY Edited May 23, 2023 by 123GO Share this post Link to post Share on other sites
953 nut 63,166 #13 Posted May 23, 2023 Probably just a typo by the person who made up the graphic illustration. Share this post Link to post Share on other sites
Warning:Unsupervised 83 #14 Posted May 23, 2023 Could be, It would just pop up during my search. I didn't chase it because my part had (G) & its common. I hit on this chart for Oregon switches too fwiw. Idk if Indak makes their switches, number system really differs but might help someone? https://www.lawnmowerpros.com/diy/index.php/lawn-mower-ignition-switch-by-terminal/ Share this post Link to post Share on other sites
Retired Wrencher 6,182 #15 Posted May 24, 2023 On 10/27/2018 at 8:05 PM, Lane Ranger said: You are a better mechanic than me Dan! Lane they do make tools to remove the connector from the housing. There are videos on YouTube shows how use them. I bought a kit with about twenty different tools. Share this post Link to post Share on other sites
