Pullstart 68,675 #1 Posted October 25, 2018 I have the Sunstrand trans from the Charger 12 and have moved the Kohler K241 backwards. I understand how to measure a belt, but the “parking brake” pulley is mobile. Where should it be located to measure for a new belt? 1 Share this post Link to post Share on other sites
Pullstart 68,675 #2 Posted October 25, 2018 1 hour ago, pullstart said: I have the Sunstrand trans from the Charger 12 and have moved the Kohler K241 backwards. I understand how to measure a belt, but the “parking brake” pulley is mobile. Where should it be located to measure for a new belt? Well th engine isn’t backwards, it’s back aways. (Shorter belt needed). Share this post Link to post Share on other sites
Achto 30,519 #3 Posted October 25, 2018 Take a measurement of how the belt would be with out the tensioner, then add an inch or two to that figure. I would think that this would be a good starting place. It might take a couple trips back to the store though. 2 Share this post Link to post Share on other sites
Pullstart 68,675 #4 Posted October 25, 2018 9 minutes ago, Achto said: Take a measurement of how the belt would be with out the tensioner, then add an inch or two to that figure. I would think that this would be a good starting place. It might take a couple trips back to the store though. Well my first attempt to measure is about 1” longer than measuring without the tensioner, so I suppose I was close! I can’t tell you how I came up with that number though! thanks Dan! 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,932 #5 Posted October 25, 2018 Take the distance you moved the engine x 2 from the original belt length. Garry 2 2 Share this post Link to post Share on other sites
Pullstart 68,675 #6 Posted October 25, 2018 2 minutes ago, gwest_ca said: Take the distance you moved the engine x 2 from the original belt length. Garry It’s not the original engine, but I think I’ve got it close to check operation. Thanks for the simple reminder though! 1 Share this post Link to post Share on other sites
peter lena 9,652 #7 Posted October 25, 2018 agree with achto, if you have a local t/s store, its easy to bring in your belt and match one up , good selection and prices, pete 1 Share this post Link to post Share on other sites
WHX?? 53,908 #8 Posted October 25, 2018 Get a couple either side what you think you need and return the ones that don't fit the best. Might save a couple of trips. 3 Share this post Link to post Share on other sites
squonk 45,118 #9 Posted October 25, 2018 3 hours ago, WHX21 said: Get a couple either side what you think you need and return the ones that don't fit the best. Might save a couple of trips. Same thing with a plumbing project. Bring your card. "Cleanout " (no pun intended) Home Cheapo or Lowes of all the fittings. Return what you don't use and with the return money buy Power Tools! 1 4 Share this post Link to post Share on other sites
jay bee 915 #10 Posted October 26, 2018 4 hours ago, squonk said: Return what you don't use and with the return money buy Power Tools! That way you don't have to explain why you needed more tools. 2 Share this post Link to post Share on other sites
squonk 45,118 #11 Posted October 26, 2018 6 hours ago, jay bee said: That way you don't have to explain why you needed more tools. Exactly! "I needed them for the project" 1 1 Share this post Link to post Share on other sites
Pullstart 68,675 #12 Posted October 26, 2018 17 hours ago, WHX21 said: Get a couple either side what you think you need and return the ones that don't fit the best. Might save a couple of trips. I went with 5/8 x 78, the local parts store was 6 bucks cheaper than tsc and 8 miles closer too. After running it around a bit, I probably should have gone with a 79. Most likely I’ll grab a 79 next time I am at the store, and toss the 78 on a hook for another some day project. 14 hours ago, squonk said: Same thing with a plumbing project. Bring your card. "Cleanout " (no pun intended) Home Cheapo or Lowes of all the fittings. Return what you don't use and with the return money buy Power Tools! Can’t say I’ve never done that before! My wife is however, very understanding of needing tools for jobs. It’s still cheaper than hiring the work out, when I can do it myself! But then again, half a wall on the outside of the house needs the vinyl put back on and I find myself wandering to the garage to play (work) or important things. I mean, the house is wrapped... it’s not like it’ll ruin anything! Share this post Link to post Share on other sites
