Dennis C. 142 #1 Posted October 24, 2018 I just located a decent 1969 W.H. 700 that includes a snowblower and mower deck. Currently it has a B & S snowblower engine in it. I believe the original had a 7hp Tecumseh. What would be a good replacement engine that is easily available? Haven't been able to locate a Tecumseh on the internet. Thanks. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,977 #2 Posted October 24, 2018 Dennis C. Enjoy the site lots of help here. Share this post Link to post Share on other sites
Racinbob 13,134 #3 Posted October 24, 2018 Unless you want to keep it as close to original as possible I'd suggest a Kohler 7 or 8hp. Easier to find and a much better engine. The install would be pretty simple. 1 2 Share this post Link to post Share on other sites
Achto 32,629 #4 Posted October 24, 2018 (edited) 1 hour ago, Dennis C. said: What would be a good replacement engine that is easily available? If you want to stay original, then I would keep looking for the correct Tecumseh engine. If original is not the goal, then my fist choice would be a Kohler K181 or Kohler Magnum 8hp. A Brigg's I/C engine would not be a bad choice either. Edited October 24, 2018 by Achto 2 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,680 #5 Posted October 24, 2018 I have a 700 at home that is going to be a similar project. It has the original 7hp tecumseh on it, but I've never been able to make it run right and I've had it for years. So now I keep my eye open for a Kohler k181 like something off of a B80 and I'm going to do an engine sway and call it a done. If you don't mind the look of a modern engine you can get a 6.5 horse predator engine at harbor freight. 1 Share this post Link to post Share on other sites
pfrederi 21,145 #6 Posted October 24, 2018 (edited) 11 minutes ago, Mike'sHorseBarn said: I have a 700 at home that is going to be a similar project. It has the original 7hp tecumseh on it, but I've never been able to make it run right and I've had it for years. So now I keep my eye open for a Kohler k181 like something off of a B80 and I'm going to do an engine sway and call it a done. If you don't mind the look of a modern engine you can get a 6.5 horse predator engine at harbor freight. Put an HH-70 on the L107 (Avatar Pic) while my Father still had it back about 1990 (Only reason was to get ACR as he was having issues with his shoulder and had been to frugal to buy an L157 in 1967). That HH70 starts instantly year round and in all that time the only issue was some dirt in the carb a few years ago. Never had a points problem (like some on my Kohlers) Think I changed the spark plug a few years ago. She is my chore tractor and is used several time sa week for three seasons and then once a week in the winter. If you want to sell your 7hp techy I would be interested... (Also have his circa 1970 Troybilt tiller with a HH60. Only used once a year but fires up on the third pull and runs great....) Edited October 24, 2018 by pfrederi 3 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #7 Posted October 24, 2018 Snowblower are a easy way to find the engines. Just measure cranks. Carboraters are easy to find on eBay. Here's my 552 with a 1967 h70 from a Toro walk behind 2 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #8 Posted October 24, 2018 I would check with A Z tractors. Lincoln fixed me up with a nice 8 hp kohler for my 855. The parts for a Tecumseh are getting hard to find . Good luck! Share this post Link to post Share on other sites
Pullstart 71,207 #9 Posted October 24, 2018 49 minutes ago, craftsmanmowerfreak said: Snowblower are a easy way to find the engines. Just measure cranks. Carboraters are easy to find on eBay. Here's my 552 with a 1967 h70 from a Toro walk behind That’s a sweet hood.. 2 Share this post Link to post Share on other sites
Pullstart 71,207 #10 Posted October 24, 2018 4 hours ago, Dennis C. said: I just located a decent 1969 W.H. 700 that includes a snowblower and mower deck. Currently it has a B & S snowblower engine in it. I believe the original had a 7hp Tecumseh. What would be a good replacement engine that is easily available? Haven't been able to locate a Tecumseh on the internet. Thanks. @Dennis C.! I have one Tecky and the rest are Kohler powered. The Kohler is a much easier engine to work on, the Tecky runs great (needs a pull cord currently though) and I believe is under appreciated, but I haven’t ever had to work on it either. The last item I purchased just for the engine was an air compressor that was leaking. Keep your eyes open, and you’ll find a decent mill for it somewhere! 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #11 Posted October 24, 2018 30 minutes ago, pullstart said: That’s a sweet hood.. Lol yea searching for anothet 1 1 Share this post Link to post Share on other sites
Pullstart 71,207 #12 Posted October 24, 2018 3 minutes ago, craftsmanmowerfreak said: Lol yea searching for anothet When you find one, I’ll give that one a home! 1 1 Share this post Link to post Share on other sites
Dennis C. 142 #13 Posted October 24, 2018 Thanks for all the replies and welcomes. This Wheel Horse really isn't a good candidate for a total restoration. I'll probably look for Kohler instead I did find a couple of Tecumseh snowblower engines of that era on Ebay. Not sure if that would be a good route for a novice. Thanks again. 3 Share this post Link to post Share on other sites
KC9KAS 4,746 #14 Posted October 24, 2018 @Dennis C. to . I have a Work Horse 700 with a newer Tecumseh 10 hp engine! Share this post Link to post Share on other sites
Dennis C. 142 #15 Posted October 25, 2018 13 hours ago, KC9KAS said: @Dennis C. to . I have a Work Horse 700 with a newer Tecumseh 10 hp engine! Do you have pictures? Share this post Link to post Share on other sites
peter lena 10,046 #16 Posted October 25, 2018 having seen a number of similar / older horses at various shows , I think the h/f engine choice is simple and dollar smart. basically building a ride around tractor, you can make it into anything, resto /mod is popular , letting you do whatever you want, good luck .pete Share this post Link to post Share on other sites
formariz 12,381 #17 Posted October 25, 2018 On 10/24/2018 at 10:40 AM, craftsmanmowerfreak said: Lol yea searching for anothet I wouldn't change it. Lots of character. When you see something like that and still functioning after all these years you have to look at it with respect. 2 Share this post Link to post Share on other sites
KC9KAS 4,746 #19 Posted October 25, 2018 9 hours ago, Dennis C. said: Do you have pictures? Not readily available. Sorry. Share this post Link to post Share on other sites
953 nut 69,124 #20 Posted October 25, 2018 On 10/24/2018 at 12:54 PM, Dennis C. said: Not sure if that would be a good route for a novice. You will find lots of information and help on this site. If you are unsure of a particular engine's suitability just gather as much information as you can and ask, you will get lots of help. You can't post links to Ebay or other sites here, but you can COPY and PASTE the write-up. Share this post Link to post Share on other sites
