weeevr 2 #1 Posted October 22, 2018 need to know if a trans from a 79 c111 8 speed is the same as one from a 80-84 c125 (8 speed) or are they close enough to use, thanks in advance Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,387 #2 Posted October 22, 2018 Welcome to the forum. Both used the 103916 model of transmission. Click on the picture. Garry 4 Share this post Link to post Share on other sites
weeevr 2 #3 Posted October 22, 2018 thanks a lot, figured as much but needed to be sure before a 6 hour drive to get it 1 Share this post Link to post Share on other sites
Achto 32,132 #4 Posted October 22, 2018 Good luck on your project. Share this post Link to post Share on other sites
953 nut 67,658 #5 Posted October 22, 2018 Hope you will share your project on here as you go along. Always better to ask the question before taking a chance. 1 Share this post Link to post Share on other sites
Pullstart 70,847 #6 Posted October 22, 2018 Welcome @weeevr! Share this post Link to post Share on other sites
stevasaurus 23,763 #8 Posted October 22, 2018 What's wrong with the one you have??? They are fixable most of the time. Share this post Link to post Share on other sites
TravelinJavelin 621 #11 Posted October 23, 2018 you will be getting some of the best support of anywhere with these guys here ..........you have a question about a wheel horse these guys here at redsquare can answer it 1 Share this post Link to post Share on other sites
weeevr 2 #12 Posted October 24, 2018 Sorry, been busy thanks for the reception C111, 79, bought at a yard sale 'bout 10 yrs ago, cheap 2 decks, snow plow, wheel weights & chains saw last week the r. side axle stickin' out about 2-21/2". jacked it up and had that much in & out play in it.use it in the fall to tow a big leaf vac. leaf season is NOW so need it pronto. so the "take it apart & fix it" thing is off the table. drove to ohio today & picked one up I bought on ebay so as all that needs to happen next is to swap it out & go this is gonna happen tomorrow. thanks again for all the info, i'll keepya posted 1 Share this post Link to post Share on other sites
stevasaurus 23,763 #13 Posted October 25, 2018 Sounds like a "C" clip, that holds onto the axle, came off or broke. It will not take much to fix that after you get the leaves picked up. Share this post Link to post Share on other sites
weeevr 2 #14 Posted October 30, 2018 Got it all up & runnin' today, pretty easy swap. saw axles with the snap ring & some with roll pins, didn't know what was in there. axle moves horizontally a coupla inches but doesn't come out so didn't make sense that a retainer that's 1/8" thick could be the issue. somewhere down the road if & when I find the ambition, I guess i'll see. thanks fot the pic Share this post Link to post Share on other sites
