saminmn 17 #1 Posted October 17, 2018 How many RPMs will the starter on a kohler 341 be? over 600? Share this post Link to post Share on other sites
pfrederi 20,669 #2 Posted October 17, 2018 Interesting question...Engine condition...(Compression) battery condition. wiring condition, temperature, Engine oil weight...so many variables. I would very much doubt you would ever get to 600 rpm just cranking. 1 Share this post Link to post Share on other sites
ebinmaine 79,138 #3 Posted October 17, 2018 1 hour ago, pfrederi said: Interesting question...Engine condition...(Compression) battery condition. wiring condition, temperature, Engine oil weight...so many variables. I would very much doubt you would ever get to 600 rpm just cranking. Agreed. I'm only forming an educated guess here but I think something in the range of 300 RPM to 350 RPM would be about normal. Maybe even a little bit less. I don't think you'd get closer to 600 engine RPM unless you removed the spark plug. Share this post Link to post Share on other sites
prondzy 3,889 #4 Posted October 17, 2018 Well the automatic compression release on the camshaft stops working after 600 or 800 rpm so less than that. 1 Share this post Link to post Share on other sites
