Dan693 510 #1 Posted October 8, 2018 (edited) I have a pair of rims that normally take 23x9.50-12 tires and I'm considering putting 23x10.50-12 tires on them. I dont have a ton of tire experience but wondered if anyone is pretty sure they will still fit being an inch wider. I think they probably will but not sure. Thoughts? Edited October 8, 2018 by Dan693 1 Share this post Link to post Share on other sites
Pullstart 68,887 #2 Posted October 8, 2018 I’m sure you’ll be fine, but for the sake of conversation, which tractor? Share this post Link to post Share on other sites
953 nut 64,139 #3 Posted October 8, 2018 No problem, did the same this spring! Share this post Link to post Share on other sites
ericj 1,579 #4 Posted October 8, 2018 A lot depends on the brand of tire you use. Carlisle run pretty close to size, other brands like deestone run smaller, the deestone's measure out to a 23x9.50x12 when mounted. The Carlisle balloon out some on the narrower 7.5 rims as compared to the 8.5 rims recommended for them. I've run the Carlisle's on the 7.5 rims with no problems Witch ever you choose put tubes in front the get go, good luck Eric j 2 Share this post Link to post Share on other sites
Dan693 510 #5 Posted October 8, 2018 Thanks for the input to all! Think I'm good to go...... 1 Share this post Link to post Share on other sites
JAinVA 4,638 #6 Posted October 9, 2018 The 10.50 tire will fit on a 7.5 rim.No problems.I recently bought a set Carlisle 10.50 ags mounted on 7.5 JD rims.The tires in my mind looked weird on that narrow of a rim. I mounted them on 8.5 WH rims and I like the difference. 1 Share this post Link to post Share on other sites
