Daron1965 644 #1 Posted October 7, 2018 I have been looking at a D-160 over the last few days. It seems to run well, (a little smoke on start up after setting a few days from the onan). It is bare bones tractor, no deck, no 3 point hitch, and needs new hydro lines. I talked him down to $600 so far, but the lines have me hesitant. Are they hard to replace, can they be made? Just looking for advice from all the knowledgeable people on here. Worth the risk at that price? Share this post Link to post Share on other sites
SylvanLakeWH 30,597 #2 Posted October 7, 2018 Do not know about the "D's" but here is some info about lines from one of the vendors here...Probably a good place to check / ask... 1 Share this post Link to post Share on other sites
Daron1965 644 #3 Posted October 7, 2018 1 minute ago, SylvanLakeWH said: Do not know about the "D's" but here is some info about lines from one of the vendors here...Probably a good place to check / ask... Thank you very much 2 Share this post Link to post Share on other sites
pfrederi 19,907 #4 Posted October 7, 2018 There are two types of hydro lines. The flexible ones similar to those shown above. You can probably find a local hydro shop that could make them up for you . There is also a hydro manifold of steel lines that go from the pump to the motor If they are leaking you have to find a good used replacement 1 Share this post Link to post Share on other sites
ericj 1,579 #5 Posted October 7, 2018 how bad are the lines leaking and what lines are leaking like posted above. I bought a 74 D160 with Kohler single years ago. Turns out the manifold was leaking and had to find a replacement one. Once I replaced the line set, then the tractor wouldn't move. Seems like the PO ran it dry on oil and wiped out the pump. All if the pistons and slippers were shot. Luckily I know a guy that used to be a dealer back in the day. H e had me bring him a pump and hydro motor off a C series tractor and took both apart and made a working pump and motor for me. Unfortunately after using it awhile the lift stopped working, tractor still ran and drove but would not lift. Got tired of the tractor and sold it This is why the guys say to check the hydro before buying a tractor, good luck eric j Share this post Link to post Share on other sites
Daron1965 644 #6 Posted October 8, 2018 It is the metal line coming off of the pump. I am a little skeptical on this purchase. Share this post Link to post Share on other sites
