Artmilaca 23 #1 Posted October 4, 2018 (edited) I just picked up a 520h that has various little problems. It has a an Onan P220 #1 on the list is that the throttle control will not stay in place. If you set it at a higher speed it will fall right back to cut off. Before I tear into this I was wondering if anybody might have a clue as to the problem. Edited October 4, 2018 by Artmilaca Additional Share this post Link to post Share on other sites
WHX?? 54,522 #2 Posted October 4, 2018 First off if I haven't done so already. Age old problem here. You will have to take the control off the dash and tighten up the rivet that holds tension on the lever. I have had to drill the rivet out and replace with machine screw and wave washers. Some had a little detent to hold it at WOT & that may be worn down as well. Fix with some brazing and Dremel work. The other alternative is just to replace the whole assembly, they are available yet. Share this post Link to post Share on other sites
Artmilaca 23 #3 Posted October 4, 2018 WHX21 Thanks for the information I will check that out Share this post Link to post Share on other sites
varosd 1,185 #4 Posted October 4, 2018 Others have squeezed the rivet with channel locks or also preened it with a hammer i bought a 416 and the PO had this elaborate cut out metal piece that swung down to lock the throttle in place it took me more time removing it than simply squeezing the rivet to fix it. Share this post Link to post Share on other sites
Ed Kennell 44,666 #5 Posted October 4, 2018 I have bought several tractors that use these as a lock. 1 Share this post Link to post Share on other sites
lynnmor 8,550 #6 Posted October 4, 2018 You should be able to put a small screw thru the rivet. Use a high strength screw like a socket head cap screw, washers and a locknut. Simply squeeze it till the friction is enough to hold the throttle in place. 2 Share this post Link to post Share on other sites
Artmilaca 23 #7 Posted October 5, 2018 Yeh, The Squeeze was going to be my first attempt. Then Mash with a hammer on the Anvil next 😂 Share this post Link to post Share on other sites
formariz 12,354 #8 Posted October 5, 2018 Have the same issue on my 520. It will come down from full throttle to about half.Same happens with my Electro. In the spirit of making things easy specially with something which will occur again in the future due to wear, this is my solution on the 520. Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #9 Posted October 6, 2018 On 10/4/2018 at 4:17 PM, Ed Kennell said: I have bought several tractors that use these as a lock. Usually I just use the vice grips to tighten up that friction joint on the throttle lever, remove the battery and squeeze away. 1 Share this post Link to post Share on other sites
Artmilaca 23 #10 Posted October 6, 2018 19 hours ago, formariz said: Have the same issue on my 520. It will come down from full throttle to about half.Same happens with my Electro. In the spirit of making things easy specially with something which will occur again in the future due to wear, this is my solution on the 520. Yep, already using that wire trick Share this post Link to post Share on other sites
Artmilaca 23 #11 Posted October 6, 2018 Thanks and I appreciate all the feedback. I will get it sorted out one way or another. Share this post Link to post Share on other sites
