Pullstart 71,369 #76 Posted October 23, 2018 Now, how to mix red and orange, that’s starting to sound like the hardest part of the build! 4 Share this post Link to post Share on other sites
ebinmaine 80,967 #77 Posted October 23, 2018 46 minutes ago, pullstart said: Now, how to mix red and orange, that’s starting to sound like the hardest part of the build! You could do Stripes. Orange. Red. Orange. Red. Orange. Red. Or a checkerboard pattern. 1 Share this post Link to post Share on other sites
19richie66 17,937 #78 Posted October 23, 2018 (edited) Waving checkered flag across the hood. Orange and red squares. Also for a battery box you could use a small latching ammo can. Edited October 23, 2018 by 19richie66 3 Share this post Link to post Share on other sites
Pullstart 71,369 #79 Posted October 23, 2018 Big dreams... 1 Share this post Link to post Share on other sites
Pullstart 71,369 #80 Posted October 23, 2018 I think length is not my issue, but height still by just a tickle. Referencing the frame as level, I made a block to space the hood mount up. I had to raise the hood by 1/4” to level it out. I might be able to massage the hood stand to raise the rear a bit. 4 Share this post Link to post Share on other sites
Pullstart 71,369 #81 Posted October 23, 2018 FYI, the green tape is NOT a cut line, it’s to reference the current battery location. 2 Share this post Link to post Share on other sites
WHX?? 58,307 #82 Posted October 23, 2018 (edited) On 10/16/2018 at 10:29 PM, pullstart said: if I’m off my rocker. Yup I kinda think so..... All I can tell you is if you clowns spent as much time building as worrying about what to name it this build would be done. Hey... I got a novel Idea... how 'bout we call it a tractor??? Edited October 23, 2018 by WHX21 6 Share this post Link to post Share on other sites
Pullstart 71,369 #83 Posted October 23, 2018 That’s a thinkin’ chair. Can’t recall the last time I used it! no turning back, no turning back... I think this notch notch will be enough to stick a big block in there! 3 Share this post Link to post Share on other sites
19richie66 17,937 #84 Posted October 23, 2018 I've been called a clown before...….. 5 Share this post Link to post Share on other sites
82Caddy 851 #85 Posted October 23, 2018 What oil pan did you decide to go with? Guessing one like this: 1 Share this post Link to post Share on other sites
Pullstart 71,369 #86 Posted October 23, 2018 So close, yet so far away. The flywheel cover interferes with the battery box. So thanks to some clowns, I’ve gotta build a battery box up front I guess! 3 Share this post Link to post Share on other sites
Pullstart 71,369 #87 Posted October 23, 2018 1 minute ago, 82Caddy said: What oil pan did you decide to go with? Guessing one like this: Still the stocker from the C-101 👍 I’m just trying to prove ya wrong 2 Share this post Link to post Share on other sites
ebinmaine 80,967 #88 Posted October 23, 2018 18 minutes ago, 19richie66 said: I've been called a clown before...….. Me tooooo!! 2 Share this post Link to post Share on other sites
PeacemakerJack 11,072 #89 Posted October 23, 2018 7 minutes ago, 82Caddy said: now, let’s see, where have I seen a pan like that before... “Cub Cadets—never heard of them!” 1 Share this post Link to post Share on other sites
Pullstart 71,369 #90 Posted October 23, 2018 How’s that saying go? Bazinga! 4 Share this post Link to post Share on other sites
82Caddy 851 #91 Posted October 23, 2018 11 minutes ago, pullstart said: Still the stocker from the C-101 👍 I’m just trying to prove ya wrong That looks like a small base big block engine (note the missing ears on the front and back). Didn't realize those came in a c-101, was under the impression that the C series used big base engines.. Thought they were mostly used in the 1045 tractors but then again I don't have an extensive knowledge of what really came in what. 3 minutes ago, PeacemakerJack said: now, let’s see, where have I seen a pan like that before... It was the first google image that came up. :Shrug: 1 1 Share this post Link to post Share on other sites
Pullstart 71,369 #92 Posted October 23, 2018 This C has a shaker plate that I removed. The Charger 12 block had the super tall base. 1 Share this post Link to post Share on other sites
82Caddy 851 #93 Posted October 23, 2018 3 minutes ago, pullstart said: This C has a shaker plate that I removed. The Charger 12 block had the super tall base. I forgot all about the shaker plates engines. 1 Share this post Link to post Share on other sites
Achto 32,844 #94 Posted October 23, 2018 (edited) 4 hours ago, pullstart said: Now, how to mix red and orange, This is real simple, just dump the two together. When Case did this they called it "Power Red"... not sure where they came up with that name, darn things look orange to me. Edited October 23, 2018 by Achto 1 2 Share this post Link to post Share on other sites
953 nut 69,827 #95 Posted October 23, 2018 Tall engine, short hood, NO PROBLEM! 1 5 Share this post Link to post Share on other sites
Pullstart 71,369 #96 Posted October 23, 2018 45 minutes ago, Achto said: This is real simple, just dump the two together. When Case did this they called it "Power Red"... not sure where they came up with that name, darn things look orange to me. I was thinking that was a (funny) possibility! Or maybe just sunrise red instead of regal red? 1 Share this post Link to post Share on other sites
PeacemakerJack 11,072 #97 Posted October 23, 2018 1 hour ago, Achto said: This is real simple, just dump the two together. When Case did this they called it "Power Red"... not sure where they came up with that name, darn things look orange to me. Yep—looks like orange to me. Call it red if you like case. Kinda like “Carousel Red” on the ‘69 GTO Judge... That also looks orange to me...just sayin! 2 Share this post Link to post Share on other sites
Pullstart 71,369 #98 Posted October 23, 2018 Maybe I’ll just spray some WD on it and call it an AC! 5 Share this post Link to post Share on other sites
Pullstart 71,369 #99 Posted October 24, 2018 So the steering shaft feels like getting in the way of the oil pan. My torch begs to differ. 1 Share this post Link to post Share on other sites
Pullstart 71,369 #100 Posted October 24, 2018 I smeared dirty grease on the bottom of a parts oil pan to spot in the upgraded shaft. All clears! I need to replace the pillow block and when I do, I’ll space it out to make up for the length I lost in the bends and all will be well. And after it is together and I tear it apart, I’ll plug up some of those “extra”holes in the frame. 3 Share this post Link to post Share on other sites
