redone 45 #1 Posted October 2, 2018 I am ready for a beer run. Brand new synolid while this restored tractor sits in storage. Today I started this tractor, then it just stop. I check with my test lamp. No fire to the coil. No fire any were. I cleaned and tighten battery cables, all grounded connections, even put a new eng switch. Nothing. Could a new synolid go bad? This tractor I have owned new in 1979. C141 hydro. All restored. Frustrating Thanks Guys Bill Share this post Link to post Share on other sites
953 nut 63,011 #2 Posted October 2, 2018 27 minutes ago, redone said: Could a new synolid go bad? Yes, but it will not stop your engine from running once it has started. With the key in the "ON" position do you have 12 Volts to the "+" post on the coil? Share this post Link to post Share on other sites
KC9KAS 4,744 #3 Posted October 2, 2018 58 minutes ago, redone said: I check with my test lamp. No fire to the coil. No fire any were. 30 minutes ago, 953 nut said: do you have 12 Volts to the "+" post on the coil? Share this post Link to post Share on other sites
AMC RULES 37,250 #4 Posted October 2, 2018 Synolid 1 Share this post Link to post Share on other sites
Ed Kennell 43,783 #5 Posted October 3, 2018 No voltage to the coil. Do you have 12V at the ignition switch terminal B ? 1 Share this post Link to post Share on other sites
oldredrider 2,553 #6 Posted October 3, 2018 Check your ammeter connections. Loose or broken wires will kill it dead. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,846 #7 Posted October 3, 2018 Attach the tester ground lead to the negative battery post when testing. Check both posts on the ammeter. There is a shut resistor in an ammeter between the posts that carries the major current and it can fail. If you don't have power on both posts install both wires on the same terminal - does not matter which one. Ammeter has failed. Then with the key in the RUN position see if you have power at the coil (+) post. If you do turn key to START and check the bare metal body of the carb for power. If you have power there check the ground cable between the engine mounting plate and the tractor frame. Good chance it is broken. Garry 1 Share this post Link to post Share on other sites
