KC9KAS 4,746 #1 Posted September 30, 2018 I have a 551 with a replacement engine, but still a 5.5 Techy. The exhaust pipe is all "wobbly" and wired to the frame. There is a heat shield but it too is floppy. Does the exhaust pipe get fastened/bolted to the hood stand then run parallel with the hood then a 45* elbow and muffler? How does the heat shield attach to the exhaust pipe? The manual would not open up for me...may not even show what I am looking for. Thank you for any assistance. Share this post Link to post Share on other sites
Achto 31,898 #2 Posted September 30, 2018 49 minutes ago, KC9KAS said: Does the exhaust pipe get fastened/bolted to the hood stand then run parallel with the hood then a 45* elbow and muffler? How does the heat shield attach to the exhaust pipe? You are correct, the pipe should get fastened to the hood stand with the use of a U bolt/small muffler clamp. The shield gets held to the pipe with a clamp that has a nut attached to it. Part #1883 Share this post Link to post Share on other sites
KC9KAS 4,746 #3 Posted September 30, 2018 @Achto Thank you. The starter solenoid is mounted right above where the exhaust pipe will be fastened...My concern was if too much heat would be generated and melt the insulation on the wires. Share this post Link to post Share on other sites
Achto 31,898 #4 Posted September 30, 2018 34 minutes ago, KC9KAS said: .My concern was if too much heat would be generated and melt the insulation on the wires. I would just relocate it 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #5 Posted September 30, 2018 1 minute ago, Achto said: I would just relocate it Where is the solenoid supposed to be mounted? Share this post Link to post Share on other sites
Achto 31,898 #6 Posted September 30, 2018 33 minutes ago, KC9KAS said: Where is the solenoid supposed to be mounted? Not positive, can't seen to find it in the manuals that I have. Could you move it to the inside of the hood stand? This would put a piece of metal between the exhaust and the solenoid at least. Share this post Link to post Share on other sites
KC9KAS 4,746 #7 Posted October 1, 2018 1 hour ago, Achto said: Not positive, can't seen to find it in the manuals that I have. Could you move it to the inside of the hood stand? This would put a piece of metal between the exhaust and the solenoid at least. I also thought about something between the exhaust pipe and the hood stand frame as an "air-gap" too. 1 Share this post Link to post Share on other sites
