rustytractornut 8 #1 Posted September 28, 2018 Does anyone have a part number for clutch seal .Large seal inside clutch orig Part number #4398. Thank you. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,528 #2 Posted September 28, 2018 Have not found anything Garry 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,528 #3 Posted September 28, 2018 The seal may use the same dimensions for bore and shaft size as the 4397 needle bearing but can't find anything on it either. Garry Share this post Link to post Share on other sites
peter lena 9,316 #4 Posted September 28, 2018 if you can remove the seal intact , bring it to a local, BEARING DISTRIBUTOR for a size match and type. Pete 1 Share this post Link to post Share on other sites
oldredrider 2,553 #5 Posted September 28, 2018 Found this in one of my files: ReliaMark. RMK-172115BHRM. Give that a try. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,528 #6 Posted September 28, 2018 A possible replacement for the Wheel Horse 4398 pto seal used in the PT-5 and 8-3411 pto clutch Found 17211SB-H-RM 1.750" ID 2.125" OD .188" deep Don't know if that is the seal size or bore and shaft dimensions. Garry Adding SKF/Chicago Rawhide or CR 17227 replacement seal for 17211SB http://www.skfextranet.com/Catalogs/457010/sealdetail.asp?s=17227 1 Share this post Link to post Share on other sites
