ebinmaine 76,633 #1 Posted September 25, 2018 As the title implies I have a 1973 no name 12 that I'm going to be building. It currently has a hydro in it that I'm going to be replacing with one of my stock 8 speeds. The seat bracket area appears to be different. Are there brake linkages that will be different? What other kind of strange little things have you run into? 1 Share this post Link to post Share on other sites
Skipper 1,790 #2 Posted September 25, 2018 (edited) This is just what springs to mind. Sure I'm forgetting something Engine pulley Other belt size, and perhaps belt guides. Plate around the shift levers. (don't remember what its called) Pedals do not work the same, so you will most likely have to do some work and changes there also. Clutch pedal and idler setup is a given. Seat support Safety switches and wiring. Hydro lift to manual lift ? And if you do it, I would suggest swapping a complete 8 speed inn. With pulley, dipstick etc. In GT world, that job is almost as big as they come. I know some will frown upon my viewpoint on it, but don't you think perhaps it was better to trade the hydro inn towards a manual? Had it been a car, I would have suggested swapping the win number, instead of everything around it But you know what. It will certainly be a learning experience, and if you do it, then post tons of pics and info Edited September 25, 2018 by Skipper 1 3 Share this post Link to post Share on other sites
ebinmaine 76,633 #3 Posted September 25, 2018 50 minutes ago, Skipper said: that job Hi Skipper and thanks for your response! Yeah, I definitely agree that it is a daunting task. I knew before I bought it that I would be doing a full frame disassembly and restoration on this one. I do absolutely agree with you that if I was looking for a manual transmission tractor that would be the better way to go. That part really doesn't bother us very much though. My honey and I totally rebuilt her 657 right down to the last nut bolt washer and screw.... and now we are getting ready to put back together the C160 cinnamon horse after doing the same dismantling procedure. I do have an interesting old farm tractor style spring seat from one of the auction purchases that I made. Came with a set of modified mid-60s rear fenders and tool box. Lift mechanism is not on this tractor anyways and I'm also not going to put one on so that part is cool too. I'll have to look in my pile O' stuff and see what I have for pedals and linkages. Must be something in there..... 2 Share this post Link to post Share on other sites
ebinmaine 76,633 #4 Posted September 25, 2018 1 hour ago, Skipper said: Engine pulley Oh yes I forgot... What is different about the engine pulley? Different sizes? 1 Share this post Link to post Share on other sites
Skipper 1,790 #5 Posted September 25, 2018 Yes. The hydro runs 1:1, The Manual has a way smaller engine pulley. At least 2:1 if I remember correct. Or you could leave it as is, and have a race horse................... 3 1 Share this post Link to post Share on other sites
squonk 45,118 #6 Posted September 25, 2018 One thing you need to know: The hydro is heavy! 1 Share this post Link to post Share on other sites
ebinmaine 76,633 #7 Posted September 25, 2018 6 minutes ago, Skipper said: Yes. The hydro runs 1:1, The Manual has a way smaller engine pulley. At least 2:1 if I remember correct. Or you could leave it as is, and have a race horse................... Hhmmmm..... Hehehe..... That sounds like it could be somewhat interesting. And it also has a low gear for when I want to do regular stuff. 2 minutes ago, squonk said: One thing you need to know: The hydro is heavy! That's okay Mike. But thank you. I'll just get my honey to move it around. She's very strong. You know, sort of. 2 Share this post Link to post Share on other sites
953 nut 63,619 #8 Posted September 25, 2018 Eric, I wouldn't recommend doing this unless you have a donor tractor with the 8 speed and all the linkage etc. sitting right there. There are a lot of parts and pieces and you will drive yourself crazy (you are almost there anyway ) making little bits and pieces. That being said and knowing you will do it anyway, 2 1 Share this post Link to post Share on other sites
ebinmaine 76,633 #9 Posted September 25, 2018 Just now, 953 nut said: Eric, I wouldn't recommend doing this unless you have a donor tractor with the 8 speed and all the linkage etc. sitting right there. There are a lot of parts and pieces and you will drive yourself crazy (you are almost there anyway ) making little bits and pieces. That being said and knowing you will do it anyway, Richard my long-distance friend I've been way past crazy for a good many years. And you're right. I'm going to do this anyway. Winter project, you know. But all that being said and done. We do actually have at least two different donor tractors and also the auction pile that I can pull parts from. You give my honey a tractor and a pile of wrenches and she'll take the whole thing apart in less than one day and have it painted and a nice fresh pile of pretty Parts just a few days later. Then, between the two of us and some assembly and parts manuals... Well I don't know. It's just our Twisted way of having fun. 1 Share this post Link to post Share on other sites
Jerry77 1,218 #10 Posted September 25, 2018 50 minutes ago, ebinmaine said: That's okay Mike. But thank you. I'll just get my honey to move it around. She's very strong just so you know - it is 180 pounds...and awkward to handle...happy hernias..... 2 Share this post Link to post Share on other sites
ebinmaine 76,633 #11 Posted September 25, 2018 5 minutes ago, Jerry77 said: just so you know - it is 180 pounds...and awkward to handle...happy hernias..... This one won't actually be that bad.... Only part of it is there and it's empty of fluids. 1 Share this post Link to post Share on other sites
953 nut 63,619 #12 Posted September 25, 2018 1 minute ago, ebinmaine said: it's empty of fluids Wow, that cuts it down to 170 pounds! 1 Share this post Link to post Share on other sites
ebinmaine 76,633 #13 Posted September 25, 2018 3 minutes ago, 953 nut said: Wow, that cuts it down to 170 pounds! well there's no fan and there's no filter and there's other stuff missing that should be bolted onto the side like a pulley or whatever. 160 lb Max! HAHAHAHAHHAHAHAHA !!!!! 1 Share this post Link to post Share on other sites
pfrederi 19,520 #14 Posted September 25, 2018 Bottom line they made a 12 no name 8 speed as well. You should look at the parts diagrams for it and the auto 1-0460 and 1-0465 and see how many different parts you will need...it will be a bunch 2 Share this post Link to post Share on other sites
ebinmaine 76,633 #15 Posted September 25, 2018 1 minute ago, pfrederi said: Bottom line they made a 12 no name 8 speed as well. You should look at the parts diagrams for it and the auto 1-0460 and 1-0465 and see how many different parts you will need...it will be a bunch Oh yeah. The whole back half of the tractor. And then some..... Definitely going to turn out to be a Franken horse project. no worries. It'll give us something to do for a bit. Share this post Link to post Share on other sites
Chris G 3,363 #16 Posted September 25, 2018 Well I'm currently making my 14hp b80. It's kinda of a similar deal. I had a bronco 14 auto and I was just gonna transfer a 8 speed to it. Well when I realized how many parts I would have to change, I ended up just getting the b80 to plant the motor on. I also got lucky and found a 14hp 8 speed that had no engine or hood. But it did have the choke and throttle cables i needed, belt guard, manual pto and a few other odd things. So my opinion if ya got a good motor I would find a good roller to transplant to. Save a lot of wondering and searching. 1 Share this post Link to post Share on other sites
