Torrence20 23 #1 Posted September 23, 2018 Just picked up a 2110k804 20652 from a buddy and got it running but the starter makes one hell of a grinding noise. Upon inspection thd first 1/4 of the bendix is ground off. The armature shaft feels too loose, I’m assuming this is a bronze bushing wear issue? Anyone know what size I need to replace it?. I’ve read a bunch on taking the starter out but nothing on fixing my specific problem Share this post Link to post Share on other sites
JAinVA 4,638 #2 Posted September 23, 2018 From this side I can't tell if you have a K series or a Magnum 10.Either way buy a new starter.For the cost of the parts to fix what you have you could get a new one. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,532 #3 Posted September 23, 2018 Here is the Kohler parts list for the M10S-461521 if that is what you have. That will give you original part numbers to search for replacement parts. Click on the picture and download from there. There should also be a bushing in the Bendix drive but that requires replacement of the drive. That plus wear in the drive end armature bushing can add up. You can get a aerosol can of graphite with a tube that works well in this application. The solvent evaporates real quick leaving just the graphite so it does not attract dust which is what wears the bushings. Have also sprayed the ring gear on the flywheel. Did not reduce the noise but it has not let me down either. This may be the same parts page but most numbers have been changed so they have to looked up individually https://www.partstree.com/parts/kohler-engines/engines-horizontal/m10-461521-kohler-m10-engine-magnum-wheel-horse-10hp-7-5kw-specs-461500-461541/electric-start-11-10-501-rev-3-15-2006-to-show-group-description/ Here is a unit available in Canada from a Stens dealer. Just more info to help locate what you need https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=5587 This is what I was looking for but not listed for your starter number https://www.bantasaw.com/catalog/viewproduct.asp?i=1475&p=5140 Garry 2 1 Share this post Link to post Share on other sites
Torrence20 23 #4 Posted September 23, 2018 It’s a 10 hp magnum Koehler. I guess I’ll just take it apart and see what I’m working with. I can get some bushings at a local hardware store if I can fine one close I’ll just turn it down to make it fit. Thanks for all the info! Also anyone know where I can find a regular old gas cap for one of theses that does not have the fuel guage crap in/on it? Share this post Link to post Share on other sites
520hC-120 136 #5 Posted September 23, 2018 30 minutes ago, Torrence20 said: It’s a 10 hp magnum Koehler. I guess I’ll just take it apart and see what I’m working with. I can get some bushings at a local hardware store if I can fine one close I’ll just turn it down to make it fit. Thanks for all the info! Also anyone know where I can find a regular old gas cap for one of theses that does not have the fuel guage crap in/on it? You can most likely find a gas cap on eBay. If not then TSC may have it. Share this post Link to post Share on other sites
953 nut 70,310 #6 Posted September 23, 2018 Tractor supply has a good selection, take the old one along to match up. https://www.tractorsupply.com/tsc/search/gas cap toro Be sure to only use ethanol free gas, the ethanol will foul a fuel system. https://www.pure-gas.org Share this post Link to post Share on other sites
Torrence20 23 #7 Posted September 23, 2018 Thanks for the info I’ll post back with a solution if I come up with one for the starter Share this post Link to post Share on other sites
Anglo Traction 761 #8 Posted September 23, 2018 Maybe too late for this, but if you do spot it, have a look'see at this TOPIC of sometime back. It may help resurrect the old one before resorting to a new Starter. Also check the number of teeth on the old Bendix Drive gear before buying. They can have 10 or 13 teeth if I remember rightly?. 1 Share this post Link to post Share on other sites
Torrence20 23 #9 Posted September 24, 2018 Sofor what it’s worth it pulled the starter off tonight and sure enuff the bushing on the end was shot. I took some measurements so I can grab a bronze bushing tomorrow at work they are about 2.50$ Its a little larger then 1/2 i.d and a little under 3/4 o.d so it will be easy to find one that will work. While on the lathe turning this bushing to size I was pondering if I should turn a small chamfer on the end of the bendix that’s chewed up to try to save it... anyone have any thoughts on if that would help engage the ring gear? Share this post Link to post Share on other sites
953 nut 70,310 #10 Posted September 24, 2018 Think I would spring for the $ 20 to buy a new Bendix while you are at it. Share this post Link to post Share on other sites
Torrence20 23 #11 Posted September 24, 2018 (edited) I think I need to keep searching.. the only bendix I found was 45+ ups wich was about the price of an after market starter Edited September 24, 2018 by Torrence20 Share this post Link to post Share on other sites
WH nut 553 #12 Posted September 24, 2018 I would check these guys out. https://www.dbelectrical.com/ 1 Share this post Link to post Share on other sites
953 nut 70,310 #13 Posted September 24, 2018 10 hours ago, Torrence20 said: I think I need to keep searching.. the only bendix I found was 45+ ups wich was about the price of an after market starter Check it out, lots to choose from. You will need to give your search a little more information. https://www.google.com/search?q=kohler+bendix&rlz=1C1JZAP_enUS799US799&source=lnms&tbm=shop&sa=X&ved=0ahUKEwiHhYy7vdPdAhUsyoMKHdbDCOoQ_AUIDigB&biw=1366&bih=657 Share this post Link to post Share on other sites
Torrence20 23 #14 Posted September 24, 2018 Thank you both. That dbelectrical carries a ton of stuff! Ty for that link I feel that will come in handy. And your search definitely yielded much better results 1 Share this post Link to post Share on other sites
Torrence20 23 #15 Posted September 25, 2018 On another note what’s a machine like this worth. Just a tractor no attachments rough shape but functional? Not looking for a “bluebook” value but if one of yous happened upon this at a garage sale turned the key and it started and you could drive it what would you be willing to pay Share this post Link to post Share on other sites
953 nut 70,310 #16 Posted September 25, 2018 9 hours ago, Torrence20 said: what’s a machine like this worth. Value would depend on how plentiful are in your area and how badly you wanted it. To me a cosmetically challenged running 300 model would be worth about $ 200 without a good deck. 2 Share this post Link to post Share on other sites
Torrence20 23 #17 Posted September 25, 2018 I have seen some for sale around here on selling sites. But they are all asking 500+ Share this post Link to post Share on other sites
Torrence20 23 #18 Posted September 26, 2018 Well my 2$ bushing worked. turned it down to fit, cleaned up the edge on the bendix cleaned everything up and put it back on and it works flawlessly and no noise at all it engages and disengages very smooth! 2 1 Share this post Link to post Share on other sites
Torrence20 23 #19 Posted September 27, 2018 So onto the next chapter of this old horse, the headlights don’t work one is burnt out I’ve tested them. No power coming from the switch so I need to pull the panel off and test the switch. I was reading on here the other day a guy had installed led lights that were direct replacements of theses but I can’t for the life of me find that thread. Any one know what’s it is? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,532 #20 Posted September 27, 2018 Your headlamps are powered by AC current from a second stator on the flywheel so the engine needs to run for them to work. I don't know if Led lamps will work on AC power. Some may work. Garry Share this post Link to post Share on other sites
Anglo Traction 761 #21 Posted September 27, 2018 11 hours ago, Torrence20 said: I was reading on here the other day a guy had installed led lights that were direct replacements of theses but I can’t for the life of me find that thread. Any one know what’s it is? Maybe this one- LED Share this post Link to post Share on other sites
953 nut 70,310 #22 Posted September 27, 2018 40 minutes ago, Anglo Traction said: Maybe this one- LED The LEDs you have directed us to are great on the older with 1157 lamps. This thread covers the 4" sealed beam direct replacement used on the 312. Share this post Link to post Share on other sites
Anglo Traction 761 #23 Posted September 27, 2018 4 hours ago, 953 nut said: The LEDs you have directed us to are great on the older with 1157 lamps. This thread covers the 4" sealed beam direct replacement used on the 312. My apologies, misunderstood the OP's lamp type 1 Share this post Link to post Share on other sites
Torrence20 23 #24 Posted September 27, 2018 3 hours ago, Anglo Traction said: My apologies, misunderstood the OP's lamp type No worries thank you though Share this post Link to post Share on other sites
Torrence20 23 #25 Posted September 28, 2018 Welp put in new lights and a new toggle switch, took out some crappy panel clips and installed some rivnuts changed the oil and found a new gas cap without the fuel guage on it and no hole in the top.. anyone sick of me yet? Share this post Link to post Share on other sites
