Realwhiteboy 0 #1 Posted September 21, 2018 I have a 8 speed axle,3 speed with reverse and high and low option. It has what looks like a 8 to 10 inch pulley with a tapered shaft. Also has disc brake and tge high and low shifter is at the back of the axle. Anyone know which one this would be? Share this post Link to post Share on other sites
The Tuul Crib 7,340 #2 Posted September 21, 2018 Welcome to red square! Not sure what you have what you need, but pictures will help bunches somebody should be a long that can help as well! Welcome to the addiction ! 1 Share this post Link to post Share on other sites
pfrederi 19,516 #3 Posted September 21, 2018 What is the diameter of the axle shaft itself...1" or 1-1/8" Share this post Link to post Share on other sites
stevasaurus 23,536 #4 Posted September 21, 2018 Like Paul said...axle diameter and a picture of the left and right side of the trans. See if there are any numbers & letters up by the shifter...casting date. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,932 #5 Posted September 21, 2018 Sounds like a Foote transmission Garry 1 Share this post Link to post Share on other sites
Realwhiteboy 0 #6 Posted September 21, 2018 Not sure size of axle shafts at the moment has 5x4.5 hubs an 12 inch wheels. The pulley is vertical instead of on top. Share this post Link to post Share on other sites
stevasaurus 23,536 #7 Posted September 22, 2018 post a picture...it will make it easy to ID then. All axles are either 1" or 1 1/8" and we have 8 speed trannys with both. Share this post Link to post Share on other sites
