Skipper 1,792 #51 Posted September 24, 2018 Well if you have a bunch of volt meters (yeah I know, other gauges will do too). Then you gather all the + wires into a bundle, and solder them to a main + wire in ONE point, instead of cutting wires here and there to steal power. Same with the grounds. But again, the consumption in this voltmeters case is negligible , so you can pretty much hook it up where ever, without any risk. When I get home I can do a consumption readout for you, so you know what we are talking about current wise. 1 1 Share this post Link to post Share on other sites
bo dawg 640 #52 Posted September 25, 2018 Yea I have 2 others besides the volt meter. A oil temp gauge, and an hr meter. I was running to temp gauge first then jump over from there to volt and hr meters. Share this post Link to post Share on other sites
bo dawg 640 #53 Posted September 25, 2018 On 9/24/2018 at 2:10 PM, Skipper said: Well if you have a bunch of volt meters (yeah I know, other gauges will do too). Then you gather all the + wires into a bundle, and solder them to a main + wire in ONE point, instead of cutting wires here and there to steal power. Same with the grounds. But again, the consumption in this voltmeters case is negligible , so you can pretty much hook it up where ever, without any risk. When I get home I can do a consumption readout for you, so you know what we are talking about current wise. Couldnt I put a fuse block in to power each gauge/meter, plus it would have its own fuse safety? Share this post Link to post Share on other sites
953 nut 68,175 #54 Posted September 26, 2018 2 hours ago, bo dawg said: Couldnt I put a fuse block in to power each gauge/meter, plus it would have its own fuse safety? That would be total overkill! Gauges (except Amp Meters) have negligible current draw and can be safely added to a lighting/accessory circuit that is already fuse protected. 1 Share this post Link to post Share on other sites
