The Tuul Crib 7,338 #1 Posted September 15, 2018 Didn't these tractors come with wrenchs to remove the blades? Any ideas where I can get a set? Share this post Link to post Share on other sites
JAinVA 4,636 #2 Posted September 15, 2018 The wrench for decks with the smaller nut that is part of the spindle is available on Ebay.The spindle nut is just an 1 1/8" nut. I use an 1 1/8" socket and a homemade wrench to install the blade.To break the spindle nut free I use a block of wood to keep the blade from turning.Impact wrench eliminates the need for a block.Again the wrench is a available on E-bay for around $26.00 plus shipping. 2 Share this post Link to post Share on other sites
The Tuul Crib 7,338 #3 Posted September 15, 2018 22 minutes ago, JAinVA said: The wrench for decks with the smaller nut that is part of the spindle is available on Ebay.The spindle nut is just an 1 1/8" nut. I use an 1 1/8" socket and a homemade wrench to install the blade.To break the spindle nut free I use a block of wood to keep the blade from turning.Impact wrench eliminates the need for a block.Again the wrench is a available on E-bay for around $26.00 plus shipping. What is the size of the smaller nut? Share this post Link to post Share on other sites
JAinVA 4,636 #4 Posted September 16, 2018 (edited) 1 1/8" I had a hard time justifying spending $26.00 on something I only use occassionally.The wrench I made is of mild steal and is used only to secure the spindle after the nut is broken loose.The older 42" deck I have has a huge nut attached to the spindle.I use a pipe wrench to secure the spindle once the nut is broken free. Edited September 16, 2018 by JAinVA Share this post Link to post Share on other sites
lynnmor 7,632 #5 Posted September 16, 2018 43 minutes ago, JAinVA said: 1 1/8" I had a hard time justifying spending $26.00 on something I only use occassionally.The wrench I made is of mild steal and is used only to secure the spindle after the nut is broken loose.The older 42" deck I have has a huge nut attached to the spindle.I use a pipe wrench to secure the spindle once the nut is broken free. I bought a wrench with a new tractor in 1991. That wrench is, like you say, mild steel and will spread easily making it useless. Find a flea market wrench and grind down the thickness if necessary. 1 Share this post Link to post Share on other sites
JAinVA 4,636 #6 Posted September 16, 2018 Impact wrench for me.Nuts come off fast and no other wrench needed. 3 Share this post Link to post Share on other sites
SylvanLakeWH 27,792 #7 Posted September 16, 2018 2 hours ago, JAinVA said: Impact wrench for me.Nuts come off fast and no other wrench needed. Share this post Link to post Share on other sites
timo4352 147 #8 Posted September 16, 2018 9 hours ago, JAinVA said: Impact wrench for me.Nuts come off fast and no other wrench needed. Nope. Worked for me in the past..., but this time around removing the blades the whole spindle spun - loosening the nut on the top! You need to hold that lower spindle nut. The impact is a wonderful thing.... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,285 #9 Posted September 16, 2018 11 hours ago, The Tool Crib said: What is the size of the smaller nut? A trick to determine wrench size Take the thread size say 5/8" = 10/16" + 50% = (10/16 +5/16) = 15/16" wrench size. 3/4" = 6/8" + 50% = (6/8 + 3/8 = 9/8) = 1-1/8" wrench size. Does not work for all sizes but reduces the number of trips to the tool box. Garry 1 Share this post Link to post Share on other sites
pfrederi 18,406 #10 Posted September 17, 2018 (edited) an old blade. a hacksaw and some time at the grinding wheel. 0$ and about 10 minutes. Works great very tough no spreading... Edited September 17, 2018 by pfrederi 2 2 Share this post Link to post Share on other sites
