520hC-120 136 #1 Posted September 12, 2018 (edited) Hi guys, My pto safety switch doesn’t work. A little two wire connector was next to it and has a pink wire and a brown (or black) wire. What does this connector do. Any help would be nice thanks. Also may I have the wiring diagram for just the head and taillights for a 520h Edited September 12, 2018 by 520hC-120 Share this post Link to post Share on other sites
Achto 31,814 #2 Posted September 12, 2018 First I would check to see if you have any power going to the light switch (with the key in the on position). If you don't then start by looking at the fuses. Then see if you have power going from the switch, if not the switch may be bad. Basically trace every circuit through until you find the problem. Down load a manual from here so you have a wire diagram, it will make life a little easier. If your PTO does not work, a bad fuse or fuse connection may effect both circuits. Share this post Link to post Share on other sites
520hC-120 136 #3 Posted September 12, 2018 (edited) I just got all lights working still need to trace pro safety switch. I think that the green and yellow fans have been messing with my horses Edited September 13, 2018 by 520hC-120 1 Share this post Link to post Share on other sites
520hC-120 136 #4 Posted September 13, 2018 And there are no wires or connectors near the safety switch. This harness has definitely been messed with before. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,234 #5 Posted September 13, 2018 Did you not join the pink and gray together in an earlier post? Not common to join wires of different colors. What is the model number and serial number of your tractor? They are not all wired the same. Garry Share this post Link to post Share on other sites
520hC-120 136 #6 Posted September 13, 2018 Yes previously I joined wires to fix my no spark problem. It worked fantastically (knock on wood). That was a different connector though and was already connecting the wires of different colors. I think my 520h was tinkered to the point of having no fuse block. I cannot find one. I will work on getting you those numbers tonight. Share this post Link to post Share on other sites
Kurt-NEPA 756 #7 Posted September 13, 2018 18 minutes ago, 520hC-120 said: Yes previously I joined wires to fix my no spark problem. It worked fantastically (knock on wood). That was a different connector though and was already connecting the wires of different colors. I think my 520h was tinkered to the point of having no fuse block. I cannot find one. I will work on getting you those numbers tonight. What year 520H do you have? The 1988 and 1989 models do not have the fuse block. If you want a fuse block for a later 520H go here http://store.wheelhorsestables.com/index.php?route=product/product&product_id=94 Share this post Link to post Share on other sites
520hC-120 136 #8 Posted September 13, 2018 1988 thanks for the info Share this post Link to post Share on other sites
cleat 8,979 #9 Posted September 13, 2018 Here is the 1988 wire diagram. Wheel horse 520H wire diagram.pdf Cleat Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,234 #10 Posted September 13, 2018 Here is another for the 1988 Garry Share this post Link to post Share on other sites
peter lena 9,885 #11 Posted September 13, 2018 found the sloppiness of the pto lever linkage to be the major problem with mine, its erratic tracking was preventing the two lever arms from regularly picking up on/off function. until I detail disassembled it ,and found its faults , my switch would not work. I used Teflon washers as well as metal washers to firm up angle areas, also brass bushed the main swing area along with lubrication at all areas. modify and check at each change , once I found the correct straight setting , it was like smooth easy constant operation. by the way, don't bother looking for w/h parts. easier to hit a local hardware store , in their slide out box tray section, they typically have all the little goodies in picture ,slide out trays. wiring was only part of it.pete Share this post Link to post Share on other sites
