jeepdave 8 #1 Posted September 12, 2018 Once again guys, sorry for the newb question. I am trying to figure out if Grandpa's Charger 12 (1968?) is 6 or 12 volts? I am having a heck of a time finding info on the the thing. Wiring diagrams would be nice too as all of the ignition parts are currently in a box. Thanks again, Dave. Share this post Link to post Share on other sites
squonk 44,036 #2 Posted September 12, 2018 12 volts 1 Share this post Link to post Share on other sites
WHX?? 52,093 #3 Posted September 12, 2018 Get us the info on the tag under the dash and we'll get you all the manuals you need. 2 Share this post Link to post Share on other sites
jeepdave 8 #4 Posted September 12, 2018 10 minutes ago, WHX20 said: Get us the info on the tag under the dash and we'll get you all the manuals you need. Thanks. It may be 1 or 2 weeks from now, but I'll keep that in mind. Thanks again. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,562 #5 Posted September 12, 2018 Early 1968 production Charger 12's used a belt driven combination starter/generator and battery ignition. Late 1968 production Charger 12's used a Bendix starter and magneto ignition with points and condenser. The tractor model number 1-7231 was used for both. Ignition switches are completely different and the ignition terminal marked M is for magneto ignition and I (eye) for battery ignition. Here is late production info. Click on the photo. Garry 3 Share this post Link to post Share on other sites
jeepdave 8 #6 Posted September 14, 2018 Thanks for the info Garry. Looks pretty straight forward. I'll have to double check what starter/ alternator setup it has, but I want to say option 2 assuming the option 1 combo alternator/ starter doesn't look like the typical starter. Share this post Link to post Share on other sites
pfrederi 18,775 #7 Posted September 14, 2018 Since you are not 100% positive about the specific model number (and year) be aware that over its production life Chargers had 3 different ignition systems (and after 50 years the original system may have been replaced with a different style) Can shaped coil = Battery and points ignition, Triangular Coil Breakerless system no coil Magneto and points. Share this post Link to post Share on other sites
jeepdave 8 #8 Posted October 8, 2018 I was finally able to pull the model and serial numbers. Charger 12- Model 1-7241 s/n 597171 Engine K301 S s/n D067079 spec no. 47147C Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,562 #9 Posted October 8, 2018 A year newer than the last link. Click on the fuzzy picture Garry Share this post Link to post Share on other sites
953 nut 60,724 #10 Posted October 8, 2018 Glad to see you will be giving your grandfather's Charge some love. It is nice to see a stay in the family. Share this post Link to post Share on other sites
jeepdave 8 #11 Posted October 8, 2018 Thanks everyone for the info. Share this post Link to post Share on other sites
