Sailman 1,305 #51 Posted October 1, 2022 Had a C-160 I almost bought. Came with several implements. Most uncommon one was the front mounted AIR COMPRESSOR. Ran off the PTO. 1 Share this post Link to post Share on other sites
ebinmaine 76,151 #52 Posted October 1, 2022 6 minutes ago, Sailman said: Had a C-160 I almost bought. Came with several implements. Most uncommon one was the front mounted AIR COMPRESSOR. Ran off the PTO. That's one I think about quite often. Maybe combined with a generator. @Rob J. Or maybe @OldWorkHorse and I have thought it out. Share this post Link to post Share on other sites
Darb1964 1,129 #53 Posted October 1, 2022 I have a water pump that I rigged up for the front of my WH. I use it all summer to water my gardens and fill my pool. 2 Share this post Link to post Share on other sites
Rob J. 1,942 #54 Posted October 1, 2022 11 minutes ago, Darb1964 said: I have a water pump that I rigged up for the front of my WH. I use it all summer to water my gardens and fill my pool. What did you draw the water from? Share this post Link to post Share on other sites
Darb1964 1,129 #55 Posted October 1, 2022 1 minute ago, Rob J. said: What did you draw the water from? I have a brook that runs through my property, this year was very dry and I was worried it would not produce enough water. I was using it every day. It never pumped dry, luckily. 2 Share this post Link to post Share on other sites
Rob J. 1,942 #56 Posted October 1, 2022 (edited) 27 minutes ago, Darb1964 said: I have a water pump that I rigged up for the front of my WH. I use it all summer to water my gardens and fill my pool. 1 hour ago, ebinmaine said: That's one I think about quite often. Maybe combined with a generator. @Rob J. Or maybe @OldWorkHorse and I have thought it out. I have most of the parts needed for both the generator and an air compressor. The generator I have is a WH 3k, not the 5k which is quite a bit more powerful so it won’t be a powerhouse by any stretch but will provide emergency power for certain applications. As far as the air compressor what I have planned is taking an old very heavy duty industrial air compressor pump and pair it with a tank and place it outside in its own room attached to the garage and pipe line on the inside. I don’t want to use an electric motor simply because of the draw they take to start the compressor. I want to use the front PTO to run the pump. I think I’ll either find a 16hp Kohler or this Lombardini diesel I’ve had my eye on. I have to get a couple more horses for these tasks. 😉 that’s my excuse and I’m sticking with it! 😂 Edited October 1, 2022 by Rob J. 2 Share this post Link to post Share on other sites
Darb1964 1,129 #57 Posted October 1, 2022 12 minutes ago, Darb1964 said: I have a brook that runs through my property, this year was very dry and I was worried it would not produce enough water. I was using it every day. It never pumped dry, luckily. I found this photo of the book, not great. That's where I put the suction line. This photo was taken in late March. 1 Share this post Link to post Share on other sites
ebinmaine 76,151 #58 Posted October 1, 2022 6 hours ago, Rob J. said: . I have to get a couple more horses for these tasks @SylvanLakeWH Jim and I absolutely agree. 6 hours ago, Rob J. said: that’s my HIGHLY LOGICAL REASON and I’m sticking with it! Fixed it for ya .. 1 1 Share this post Link to post Share on other sites
DarnellGates 1 #59 Posted February 23, 2023 (edited) I'm sure you have some great implements, but why not think outside the box and get something a little uncommon? Depending on what you need, a manure spreader or a rotary rake might be just the thing. If you're looking for something a little more advanced, you might consider a workover rig drilling implement. It's great for drilling into the ground and can be used for a variety of applications. It might take a bit more effort to get your hands on one, but it could be a great addition to your collection. The possibilities are endless! Edited February 24, 2023 by DarnellGates 1 Share this post Link to post Share on other sites
