Terry T 1 #1 Posted September 9, 2018 I recently acquired a 216-5, 500 hours on meter, great shape; Shifting requires lots of pressure to get to go into gears--sorta like bang shifting. Normal? Share this post Link to post Share on other sites
cleat 8,747 #2 Posted September 9, 2018 Does it shift easily with engine off. If so then the belt is not fully releasing with clutch pedal depressed. I had a 210-5 and it did that. Turned out the little belt guide pins by the engine pulley were not in the right place up fairly close to the pulley. Moved them in and it shifted fine after that. Share this post Link to post Share on other sites
Terry T 1 #3 Posted September 9, 2018 help me out do you have a pic and what dimension am I shooting for? Share this post Link to post Share on other sites
cleat 8,747 #4 Posted September 9, 2018 No pic, I sold that machine but under the engine by the drive pulleys you should have round pins just outside the belts that keep the belts from coming off the pulleys. Just make sure they are adjusted so they are almost touching the pulley / belt but not rubbing. Here is an example of what I am talking about. Look at item #14 in the attached file. 3315-195 1992 Tractor 200-Series IPL.pdf Cleat Share this post Link to post Share on other sites
