FatJackDurham 318 #1 Posted September 1, 2018 My 310-8 doesn’t move forward or backwards when I put the shifter into any gear position. It moves so freely, I feel like it’s not engaged correctly inside the transmission. THe hi-lo shifter engages correctly and moves well, based on the feel. The tractor pushes freely forwards and backwards whereever the shifter lever is, so I feel it’s either stuck in neutral or something inside is broken. What do you think and what is the procedure going to be like to fix this. How hard, how much time, etc. The transmission drips at the back, so I was afraid I was going to have to take it apart and re gasket it anyway, but, I am approaching the limit to how much time and money I want to spend on it. Please, give me some feedback about tranny issues, leak fixing, shifters, costs, time, etc. Share this post Link to post Share on other sites
953 nut 66,699 #2 Posted September 1, 2018 If this is a newer model there is a strut on the clutch that keeps it from doing a wheelie. Be sure the clutch pedal is returning to the top all the way. Share this post Link to post Share on other sites
daveoman1966 3,883 #3 Posted September 1, 2018 Seems to me the BALL at the end of your gear-shift lever has come loose on the DOG POINT SCREW and is just flopping around. Pull the shift boot up and you'll see this image. This is the NEUTRAL position. To adjust the dog-point screw, first release the JAM NUT that holds it in place. There is a small hole in the ball of the shift lever....the dog-point screw fits in that hole. Wiggle the BALL of the shift lever to where you can FEEL it and tighten the SET SCREW to where the ball is rather stiff to move around. Then, back off the set screw 1/4 turn and tighten the JAM NUT to hold it. 2 1 Share this post Link to post Share on other sites
FatJackDurham 318 #4 Posted September 3, 2018 Well done, Dave! I got that tip from gwest_CA in another post, but your picture made the difference! She drives! 1 Share this post Link to post Share on other sites
daveoman1966 3,883 #5 Posted September 4, 2018 I'm an admitted thief. I stole that pic a while back from someone....lol. As long as it helps...all is well. 1 Share this post Link to post Share on other sites
