Schrec050584 2 #1 Posted August 31, 2018 Can anyone tell me the size or share a link or part number where i can find hood hold downs and a seat shock. Also what size bolts are used for the shock. I have spacers already. Share this post Link to post Share on other sites
953 nut 63,101 #2 Posted August 31, 2018 Check this out for the hood hold downs. https://www.actusinc.com/pdf/Latch_Product_Brochure.pdf Share this post Link to post Share on other sites
chev0545 236 #3 Posted September 1, 2018 call a to z tractor.used but cheap.i get my strut's from amazon. Share this post Link to post Share on other sites
Tankman 3,525 #4 Posted September 1, 2018 Just ordered four 3” hold downs. They look to be exactly like NOS, Inexpensive, shipping was more. Thanks, 953 Nut! 1 Share this post Link to post Share on other sites
Schrec050584 2 #5 Posted September 1, 2018 2 hours ago, Tankman said: Just ordered four 3” hold downs. They look to be exactly like NOS, Inexpensive, shipping was more. Thanks, 953 Nut! Where from? Share this post Link to post Share on other sites
953 nut 63,101 #6 Posted September 1, 2018 6 minutes ago, Schrec050584 said: Where from? On 8/31/2018 at 5:43 PM, 953 nut said: Check this out for the hood hold downs. https://www.actusinc.com/pdf/Latch_Product_Brochure.pdf Share this post Link to post Share on other sites
Tankman 3,525 #7 Posted September 1, 2018 1 minute ago, Schrec050584 said: Where from? The 953nut’s link above. Ordered the 3 inchers and a couple of pins. My Work Horse has rivets holding the rubber top end in place. Easy enough to flat bottom drill off. Very cheap and appear, “exact match”. 1 Share this post Link to post Share on other sites
Blue Delta 35 #8 Posted September 4, 2018 Recommend going aftermarket on the seat strut as Chev mentioned, ones from Toro must be made from gold for what they charge. Share this post Link to post Share on other sites
Tankman 3,525 #9 Posted September 5, 2018 I hate the parts lists, i.e.: TORO part number. Why not read, i.e.: bolt, hex 3/8-16 x 2"? TOO EASY!!!! Share this post Link to post Share on other sites
ericj 1,579 #10 Posted September 5, 2018 problem is the bolts aren't 2", they are 1 7/8" or something dumb like that. eric j Share this post Link to post Share on other sites
Blue Delta 35 #11 Posted September 5, 2018 3 hours ago, Tankman said: I hate the parts lists, i.e.: TORO part number. Why not read, i.e.: bolt, hex 3/8-16 x 2"? TOO EASY!!!! You mean 321-8 (Screw-HH), 3256-22 (Washer-Flat), 3296-42 (Nut-Lock, NI) x2 & 114343 (Gas-Spring) HA You could use anything that fits through the spacer as that is the *more* important part. Share this post Link to post Share on other sites
