J HO 3 #1 Posted August 30, 2018 Hi Guys, I have a 1989 520-H with an Onan engine. It starts and runs for about 10 minutes. Then shuts off like I turned the key. After is shuts off it won't start for about an hour and has no spark. I'm thinking it has something to do with heat however, I'm not getting a temp light. Any help will be appreciated. Share this post Link to post Share on other sites
WHX?? 54,650 #2 Posted August 30, 2018 Most likely the coil is get hot and then open however it could be in the ignition trigger module. The manual below also has other trouble shooting tests. 492-4006 Onan P216 P218 P220 P224 SM.pdf Share this post Link to post Share on other sites
J HO 3 #3 Posted August 30, 2018 Thanks for the manual. I will investigate. I just didn't realize that it would actually run for a while if it was the trigger or coil. I thought if the coil or trigger went it wouldn't start at all? Share this post Link to post Share on other sites
WHX?? 54,650 #4 Posted August 30, 2018 They have been known to run fine when cold but once they warm up they expand and open up electrically. Components cool off then work until warmed up. Might want to check safety switches as well, here is a manual that will help with that. Share this post Link to post Share on other sites
BMW Phil 0 #5 Posted September 3, 2018 My '96 520 behaved this way. I replaced the trigger and its all good- found a cheap replacement on ebay. Share this post Link to post Share on other sites
J HO 3 #6 Posted September 4, 2018 THANKS guys I found a new coil and condenser kit for $50 I should come in the mail today. And it's easy to replace. If this doesn't work I will have to replace the trigger. Is there a trick to get the flywheel off? My gear pullers aren't big enough. Share this post Link to post Share on other sites
lynnmor 8,586 #7 Posted September 4, 2018 3 minutes ago, J HO said: THANKS guys I found a new coil and condenser kit for $50 I should come in the mail today. And it's easy to replace. If this doesn't work I will have to replace the trigger. Is there a trick to get the flywheel off? My gear pullers aren't big enough. I made a simple puller by using a 1/2" thick steel plate. Drilled the four holes for the flywheel and a threaded 1/-20 hole in the center. Share this post Link to post Share on other sites
J HO 3 #8 Posted September 4, 2018 Thanks. I will try that if this doesn't work. Share this post Link to post Share on other sites
J HO 3 #9 Posted September 5, 2018 Well the coil and condenser didn't change anything. I just ordered a new Trigger. Thank again guys 1 Share this post Link to post Share on other sites
J HO 3 #10 Posted September 12, 2018 has anyone tried using the PerTronix Ignitor in replace of 166-0785 166-0767? PerTronix Ignitor® Solid-State Ignition Systems 1281 Share this post Link to post Share on other sites
