Johnboy609 1 #1 Posted August 30, 2018 I have a commando 8 with the three speed transmission. Is it possible to put a six speed in that model? Thanks. 1 Share this post Link to post Share on other sites
daveoman1966 3,884 #2 Posted August 30, 2018 Yes... but you MAY have to change around some of the brake linkage...not sure on that. The bolt pattern at the FRAME PLATE is the same as in this pic.... 1 Share this post Link to post Share on other sites
ebinmaine 79,789 #3 Posted August 30, 2018 If you need pics of a 6 speed to see the linkage let me know. I have a 1267 here with one in it. Share this post Link to post Share on other sites
953 nut 67,659 #4 Posted August 30, 2018 Your best bet would be to have the tractor that donates it's transmission on hand when you do the swap so you will have all the clutch/brake linkage you need. 2 Share this post Link to post Share on other sites
Pullstart 70,847 #5 Posted August 30, 2018 Hi @Johnboy609, to ! I put a 6/8 speed (if you count reverse) in my 502, the only thing I haven’t tackled yet is a parking brake. The donor tractor being available is a huge help, and with some fittin’ and trimmin’ the hi/low lever will look right at home on your Commando. 1 Share this post Link to post Share on other sites
