mikemc53 10 #1 Posted August 27, 2018 I want to remove the PTO clutch on my C-81 and not sure what I'll need, tools-wise. It looks like snap ring pliers to start with but after the outside snap ring is off, what comes next? Thanks gang. Share this post Link to post Share on other sites
clueless 3,348 #2 Posted August 27, 2018 Once you remove the pin that connected to the U shaped rod that engages the clutch, it should slide off. The snap ring doesn't keep it on the shaft, it keeps the bearings and guts in the pulley. 1 Share this post Link to post Share on other sites
MalMac 1,334 #3 Posted August 27, 2018 The question needs to asked, what are you wanting to do as to how you want to disassemble it. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,005 #4 Posted August 27, 2018 Good info in this service manual. Pto is in section 9. Click on the picture. Garry 1 Share this post Link to post Share on other sites
953 nut 64,140 #5 Posted August 27, 2018 There may be a small break shoe at the upper left side of the PTO that would need to be removed too. 1 Share this post Link to post Share on other sites
