Schrec050584 2 #1 Posted August 25, 2018 How do i drain fluid in the rear end. Where is the drain plug. Thanks Share this post Link to post Share on other sites
JAinVA 4,638 #2 Posted August 25, 2018 Drain plug is an allen head pipe plug under the lower left side of the transmission case.Make sure the wrench is fully seated by cleaning the hex plug real good.Unless you lift the rear end up you will have to find the plug by feel. 1 1 Share this post Link to post Share on other sites
953 nut 68,782 #3 Posted August 25, 2018 When draining the transmission be sure to jack up the front end so it will drain completely, there is a hump in the bottom that will trap some old oil if you don't. 2 1 Share this post Link to post Share on other sites
JAinVA 4,638 #4 Posted August 25, 2018 Thanks,Richard I forgot that very important point! 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #5 Posted August 26, 2018 You need to get you one of these. It's a plumbing tool which is the correct size for the drain plug. Worked great for me! Share this post Link to post Share on other sites
