ebinmaine 74,528 #1 Posted August 22, 2018 You can see that there's some kind of a guard over the top of the exhaust Outlet on the engine. Also, the oil dipstick tube is different from any of the Wheelhorse tractor setups I've seen in the older rigs. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,732 #2 Posted August 22, 2018 https://www.partstree.com/parts/kohler-engines/engines-horizontal/k241-46264-kohler-k241-engine-k-series-jacobsen-10hp-7-5kw-specs-4600-46858/ Garry 1 Share this post Link to post Share on other sites
ebinmaine 74,528 #3 Posted August 22, 2018 If I want to bench test this engine can somebody tell me what wires to put where? Share this post Link to post Share on other sites
pfrederi 18,967 #4 Posted August 22, 2018 Put 12v on the coil + terminal have a good ground somewhere on the engine block and hit the A terminal on the S/G with 12 volts (heavy wire like a jumper cable) 1 1 Share this post Link to post Share on other sites
ebinmaine 74,528 #5 Posted August 22, 2018 1 minute ago, pfrederi said: Put 12v on the coil + terminal have a good ground somewhere on the engine block and hit the A terminal on the S/G with 12 volts (heavy wire like a jumper cable) Awesome. Thank you Paul. Share this post Link to post Share on other sites
WHNJ701 4,166 #6 Posted August 23, 2018 just a guess, was it off a gravely? Share this post Link to post Share on other sites
WHX?? 52,896 #7 Posted August 23, 2018 3 hours ago, ebinmaine said: If I want to bench test this engine can somebody tell me what wires to put where? Does this look like this is our first rodeo? 3 Share this post Link to post Share on other sites
KC9KAS 4,744 #8 Posted August 23, 2018 7 hours ago, jabelman said: just a guess, was it off a gravely? No, a Jacobsen, per GWEST's post. Share this post Link to post Share on other sites
