WildmanC120 613 #1 Posted August 19, 2018 I'm about to go look at a nice 520h with 500 hours on it. Says that he just changed hydro fluid recently and now it doesn't go full speed anymore. Says maybe filled too quick and air in system. What do I gotta look for??? Share this post Link to post Share on other sites
lynnmor 8,630 #2 Posted August 19, 2018 Pull the dipstick and check the oil level. Ask what oil he used, it should be 10w-30 motor oil. Look under the seat at the cam plate atop the transmission, the motion lever should move it thru the entire range of forward and reverse. Let me know if you don't want it, I may be interested. 1 Share this post Link to post Share on other sites
953 nut 64,141 #3 Posted August 20, 2018 1 hour ago, WildmanC120 said: Says that he just changed hydro fluid recently and now it doesn't go full speed anymore. I would be a bit skeptical of this. Why did he just change the oil in a good working transmission prior to selling it? Any air in the system would be flushed through in a matter of minutes. It may be a linkage issue or it could be a bad transaxle. Drive it around to warm it up then chain it to a tree and see if it will dig into the ground, do it in reverse too. 1 Share this post Link to post Share on other sites
WildmanC120 613 #4 Posted August 20, 2018 So thanks for the quick replies. I didn't look too much into the trans. I started it up and it just didn't sound right to me. I felt the exhaust the the back cylinder was nice and hot. The front though I could touch the pipe. I pulled the plug wore for front cylinder and no change in engine sound. Looks like it's got a bad engine too. Sucks as it was actually a pretty clean unmolested tractor. Here is the listing. So just a heads up to anyone that wants it...engine is probably bad. https://albany.craigslist.org/grd/d/wheel-horse-520h/6675453336.html Share this post Link to post Share on other sites
roadapples 6,987 #5 Posted August 20, 2018 Gear reduction steering and wheels worth asking price.... Share this post Link to post Share on other sites
WildmanC120 613 #6 Posted August 20, 2018 9 hours ago, roadapples said: Gear reduction steering and wheels worth asking price.... They might be but not looking for a parts machine currently Share this post Link to post Share on other sites
