Goat 2141 5 #1 Posted August 18, 2018 (edited) Just got a snowblower 0642st05 can't fine any instructions how to mount it on the tractor can some help with this ty. I have a 520h Edited August 18, 2018 by Goat 2141 Share this post Link to post Share on other sites
Ed Kennell 35,919 #2 Posted August 18, 2018 The blower could have a mount that clips on the front attach-a-matic, or it could mount to the two holes on the frame rails at the bottom front of the engine. Pictures would help ID which mount you have. Do a search in the manuals section to find your snowblower manual. Garry will probably be here soon to help you find the link. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,516 #5 Posted August 18, 2018 Here is a later manual that may be better for installation Here is a parts list for the one you have Garry 1 Share this post Link to post Share on other sites
Jody14 12 #8 Posted February 10 On 2/4/2024 at 7:29 PM, lynnmor said: My cab model number is 79943. Contact Original Tractor Cab for a windshield and wiper. Most of their offerings are the same from the bottom of the windshield up. I wish they would bring back the Wheel Horse cabs, at least for a limited production run. When you call, express interest to prod them a bit. On 2/6/2024 at 8:06 PM, lynnmor said: I have it mounted on a 1997 520H, it was on a 1991 520H previously. The 520's have a high back seat that needs the extra room in the cab that is provided on this model. Did you change the mounting brackets to bolt it to the footboards or seat pan? I measured mine and the brackets for the seat pan are 21 1/2 inches on the cab. The bolts on the 417A seat pan are 10 inches apart. 1 Share this post Link to post Share on other sites
lynnmor 6,814 #9 Posted February 11 I don't understand the question. The 79943 cab is made to fit the 520H models and many others, I made no changes. The only questionable issue is the thick rubber pads on the floorboards versus the thin stuff on the earlier models since the bracket will damage the rubber even more if you clamp the thick pads. 1 Share this post Link to post Share on other sites
Jody14 12 #10 Posted February 18 On 2/10/2024 at 9:19 PM, lynnmor said: I don't understand the question. The 79943 cab is made to fit the 520H models and many others, I made no changes. The only questionable issue is the thick rubber pads on the floorboards versus the thin stuff on the earlier models since the bracket will damage the rubber even more if you clamp the thick pads. I have to get new footboard pads as mine are shot. I'll possibly have to do some trimming. I saw someone making them on the wheel horse pages, but can't remember who it was. Share this post Link to post Share on other sites
