The Tuul Crib 7,332 #1 Posted August 17, 2018 I'm needing the deck pulleys for a 42 inch deck. Anybody have any sources to find these pulleys? 1 Share this post Link to post Share on other sites
953 nut 51,759 #2 Posted August 17, 2018 You need to give more information. Not all decks use the same pulley. Share this post Link to post Share on other sites
The Tuul Crib 7,332 #3 Posted August 17, 2018 (edited) 12 minutes ago, 953 nut said: You need to give more information. Not all decks use the same pulley. Would the deck I D # help? This is on a 520 h the I D # looks like 1549SC01 Edited August 17, 2018 by The Tool Crib Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,503 #4 Posted August 17, 2018 15-48SC01 Click on the picture. Be careful as this parts list also includes the 42" deck. You will see two item 5's and two item 6's for pulleys. Garry Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,503 #5 Posted August 17, 2018 Try this again. 42" deck 15-42SC01 I think the first 5 & 6 are for the 48" deck. The second 5 & 6 are for the 42" deck. Garry Share this post Link to post Share on other sites
The Tuul Crib 7,332 #6 Posted August 17, 2018 10 minutes ago, gwest_ca said: 15-48SC01 Click on the picture. Be careful as this parts list also includes the 42" deck. You will see two item 5's and two item 6's for pulleys. Garry Thanx Gary this should help! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,503 #7 Posted August 17, 2018 When I first saw your model number 15-49SC01 I thought 48 and 49 easily misread so posted the 48" info. Then you describe it as a 42" deck so 15-42SC01 but 42 and 49 still easily misread if poorly stamped. In any case the 42 and 48 are the width of cut - not the width of the deck. Garry Share this post Link to post Share on other sites
The Tuul Crib 7,332 #8 Posted August 18, 2018 (edited) 28 minutes ago, gwest_ca said: When I first saw your model number 15-49SC01 I thought 48 and 49 easily misread so posted the 48" info. Then you describe it as a 42" deck so 15-42SC01 but 42 and 49 still easily misread if poorly stamped. In any case the 42 and 48 are the width of cut - not the width of the deck. Garry so that is an 8 and not a 9? Here's a pic of the ID # Edited August 18, 2018 by The Tool Crib Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,503 #9 Posted August 18, 2018 If it is an 8 you have a 48" deck. The height adjuster for the rear wheels is on the left of a 48" deck and the right on a 42" deck. The belt covers on a 42" deck are secured by bolts going down into the deck shell. The belt covers on a 48" deck are secured by horizontal bolts going into the side of a heavy reinforcement plate on top of the deck shell. There never was a 9 in that position and it certainly is not a 2. Garry Share this post Link to post Share on other sites
The Tuul Crib 7,332 #10 Posted August 18, 2018 (edited) 9 minutes ago, gwest_ca said: If it is an 8 you have a 48" deck. The height adjuster for the rear wheels is on the left of a 48" deck and the right on a 42" deck. The belt covers on a 42" deck are secured by bolts going down into the deck shell. The belt covers on a 48" deck are secured by horizontal bolts going into the side of a heavy reinforcement plate on top of the deck shell. There never was a 9 in that position and it certainly is not a 2. Garry One more question will this deck work on a 312-8? Great! Thanx Gary! Edited August 18, 2018 by The Tool Crib Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,503 #11 Posted August 18, 2018 Yes it will fit the 312-8. Garry 1 Share this post Link to post Share on other sites
daveoman1966 3,612 #12 Posted August 18, 2018 FYI.. the part # for Left and Right pulleys for deck model 15-48SC01 is 110146 (5/8 x 4.75" dia) The center pulley is 110147...double pulley. Share this post Link to post Share on other sites
