The Tuul Crib 7,339 #1 Posted August 11, 2018 I just got this hundred dollar turd I picked up did some adjusting cleaned it up a little runs like a top. Only one thing I'm having a hard time with is that it won't start up at the key I turn the key on and jump at the solenoid and it fires up. I know it has to be something simple maybe a starter relay or maybe a bad so annoyed! Ha! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,495 #2 Posted August 11, 2018 Post the engine numbers or the tractor model number so we can determine what is involved in the starter circuit. It is 1989 or older but that still leaves 3 or 4 different wiring diagrams. Garry Share this post Link to post Share on other sites
The Tuul Crib 7,339 #3 Posted August 11, 2018 It's a k301 spec 47828 the serial starts with 16. An 87 model? 312-8 Share this post Link to post Share on other sites
varosd 1,185 #4 Posted August 11, 2018 Pull the connection off the back of the ignition switch and inspect: a lot of times it’s just cruddy connections. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,495 #5 Posted August 11, 2018 Should be a 1986 model and one of 2 model numbers 21-12K802 21-12K803 One difference between the two is the differential bearings. Click on the picture to start and download the file from there. The starter circuit has it's own diagram Garry Share this post Link to post Share on other sites
Spareparts 85 #6 Posted August 14, 2018 Seat switch might be bad or unhooked Share this post Link to post Share on other sites
