Bill D 3,177 #1 Posted August 9, 2018 I suspect most of us have modified our Wheel Horse's in some way or another. What is your favorite mod and why? I have installed 15 inch, 3 spoke, soft touch steering wheels on all my tractors along pedals from a late 80's eight speed on my GT 1642 as I like that style better than what it came with. I have also insalled LED light under the floor boards of my primary mower in case is starts to get dark as I am finishing the lawn. Bill 8 Share this post Link to post Share on other sites
19richie66 17,937 #2 Posted August 9, 2018 I wouldn’t know where to start. An easier topic for me would be “what have you left stock and why” Overall I think the Eaton 1100 transmission swap in the gt14 would be my favorite. Mainly because I pulled it off and it kinda looks factory. Second would be the aluminum fuel tank just because my son welded it up for me. Makes it special to me. I don’t think I could ever sell this tractor. 7 7 3 Share this post Link to post Share on other sites
posifour11 723 #3 Posted August 9, 2018 Definitely lug bolts and lugnuts! 7 3 Share this post Link to post Share on other sites
JAinVA 4,638 #4 Posted August 9, 2018 Lug bolts and nuts,15" 3 spoke steering wheels when I can get them and 520 gear reduction steering.Lug bolts make mounting rear wheels easier,15 inch three spoke steering wheels fit my hand better and 520 gear reduction steering with 4 lug hubs for ease of steering. 2 3 Share this post Link to post Share on other sites
CasualObserver 3,417 #5 Posted August 9, 2018 Seat springs on my late 60s models. A little gentler ride and slightly longer reach for the clutch pedal are nice. 6 1 Share this post Link to post Share on other sites
ebinmaine 81,049 #6 Posted August 9, 2018 My B80 has quite a few changes. All tires bigger. Added fluid weight. Smaller engine pulley. Exhaust stack. ALL our tractors get rear lugs. Lotsa cool stuff !!! 5 1 Share this post Link to post Share on other sites
WHX?? 58,328 #7 Posted August 9, 2018 Stacks, lighting and anything else that doesn't require drilling holes in 60 year old sheet metal! 5 5 Share this post Link to post Share on other sites
953 nut 70,076 #8 Posted August 9, 2018 Stacks for sure, get that exhaust up in the air and out of my face. 8 3 Share this post Link to post Share on other sites
peter lena 10,103 #9 Posted August 9, 2018 http://www.wheelhorse.org/phpBB3/viewtopic.php?f=3&t=7483, added heim joints to smooth out function and remove sloppy fit. also added springs to my snow plow to follow the blade, I will get picture soon. just regularly try to improve on problems as they show up, pete 8 Share this post Link to post Share on other sites
rjg854 13,411 #10 Posted August 10, 2018 I gotta agree with the studs and lug nuts, led bulbs, seats cause most any tractor you get needs one. And 2 of my horses got stacks. So I suppose you could say I follow the herd. 2 1 2 Share this post Link to post Share on other sites
PeacemakerJack 11,080 #11 Posted August 10, 2018 Wheel studs on anything that is going to have the rear wheels changed more than once a year especially when the tires are fluid filled or have wheel weights attached. AG tires on anything that will see ground engaging attachments and on some that don’t because they look cool! Stacks on tractors that aren’t used for mowing (don’t want to accidentally tag a low tree branch!). Outside of those, it would be tractor based. Some of mine have more mods and some are pretty much stock... 5 3 Share this post Link to post Share on other sites
Machineguy 877 #12 Posted August 10, 2018 From project to running! 2 1 5 Share this post Link to post Share on other sites
Aldon 4,834 #13 Posted August 10, 2018 Two that are equal in my opinion out a couple dozen that come to mind. Additional steel bracing under the rear fenders of the Restomod GT14 build I did. Really makes a huge difference. Adding more modern attach-a-matic brackets onto my Gt14’s ditching the original style Mule contraption. i guess converting to points is a good one as well. 2 4 Share this post Link to post Share on other sites
Chris G 3,392 #14 Posted August 10, 2018 I guess one of my favorite mods would be my led lighting! Love the way they light up my horses! 7 4 Share this post Link to post Share on other sites
roadapples 6,987 #15 Posted August 10, 2018 (edited) Relocated battery to under seat of C160 after adding gear reduction steering. Also trailer hubs & wheels in the front and studs in rear hubs... Almost forgot, added backhoe off of D250... Edited August 10, 2018 by roadapples 5 4 Share this post Link to post Share on other sites
Pullstart 71,483 #16 Posted August 10, 2018 The simple things, like loaded tires... and the cool things like adding an 8 speed to Putt Putt. I like the mods that make you wonder if it came from the factory that way too, like how awesome that K-181 fits under the hood. And a cherry bomb... that’s just hot rod fun. 9 1 1 Share this post Link to post Share on other sites
Skipper 1,792 #17 Posted August 10, 2018 Many of the above, and a few more. Highest on my " to do when time allows " is a 3 cylinder diesel conversion. and a hydraulic servo steering ala automotive style, and some other far out ideas I'm contemplating. Can anyone tell me what steering wheel it is that you all talk about? 4 Share this post Link to post Share on other sites
ebinmaine 81,049 #18 Posted August 10, 2018 42 minutes ago, pullstart said: like the mods that make you wonder if it came from the factory that way Yeah... 1 Share this post Link to post Share on other sites
Achto 32,896 #19 Posted August 10, 2018 Among all the cosmetic & creature feature mods, I think the addition of hydraulic lift on my plow tractor would be my favorite. 8 3 Share this post Link to post Share on other sites
wallfish 20,724 #20 Posted August 10, 2018 Wrapping the front tires with #40 roller chain for better steering during snow blowing and snow plowing 6 3 Share this post Link to post Share on other sites
mmmmmdonuts 274 #21 Posted August 10, 2018 Does adding a FEL count as a mod if you built it yourself? Otherwise probably, converting my old Raider to get the tach-a-matic and a two inch receiver on the back. 4 4 1 Share this post Link to post Share on other sites
Skipper 1,792 #22 Posted August 10, 2018 2 hours ago, mmmmmdonuts said: Does adding a FEL count as a mod if you built it yourself? I would say that counts 5 1 Share this post Link to post Share on other sites
roadapples 6,987 #23 Posted August 10, 2018 6 hours ago, wallfish said: Wrapping the front tires with #40 roller chain for better steering during snow blowing and snow plowing Roller chain??? Really John. It may help steering, but you're too modest. I bought my backhoe. John built his.... 2 Share this post Link to post Share on other sites
C-101plowerpower 1,606 #24 Posted August 10, 2018 7 hours ago, pullstart said: The simple things, like loaded tires... and the cool things like adding an 8 speed to Putt Putt. I like the mods that make you wonder if it came from the factory that way too, like how awesome that K-181 fits under the hood. And a cherry bomb... that’s just hot rod fun. putt putt looks good, but what i want to know is, who's driving it Share this post Link to post Share on other sites
wallfish 20,724 #25 Posted August 10, 2018 2 hours ago, roadapples said: Roller chain??? Really John. It may help steering, but you're too modest. I bought my backhoe. John built his.... The hoe is a little over the top for most horse owners to build or do as a modification so I was think'n more like modifications everyone, or at least the majority can use for ideas and do to their own horse. Although EVERYONE should have a FEL and Backhoe horse! 1 4 2 Share this post Link to post Share on other sites
