bo dawg 565 #1 Posted August 6, 2018 Is the 3 point set up w/cyclinder off a D tractor same as on the C-195 ? Share this post Link to post Share on other sites
"D"- Man 827 #2 Posted August 6, 2018 I know some of the parts will swap, but not all. The cylinder should be the same. Share this post Link to post Share on other sites
bo dawg 565 #3 Posted August 7, 2018 On 8/6/2018 at 12:17 AM, "D"- Man said: I know some of the parts will swap, but not all. The cylinder should be the same. Do you know which parts will? Share this post Link to post Share on other sites
"D"- Man 827 #4 Posted August 7, 2018 I am not certain, but I think a least the bracket that holds the top link is unique to the modei, and possibly the bell crank. Share this post Link to post Share on other sites
ronwh 190 #5 Posted August 8, 2018 Bo, If you pull up a parts diagram of a C-195 3-point hitch you will need item #1, item 2 and item #11+ hardware to install a D 3-point hitch on a C-195. #1 109787 lift bar assembly #2 109786 block #11 109791 assay upper link pivo Hope this helps Ron 1 Share this post Link to post Share on other sites
bo dawg 565 #6 Posted August 12, 2018 (edited) Here’s what’s on it now, which is not much. Edited August 13, 2018 by bo dawg Share this post Link to post Share on other sites
