Goldnboy 1,063 #1 Posted July 31, 2018 I have leads on a C145 that was running when parked. Has 4 flat tires is there a special lever to disengage hydro to roll? Any areas to key into? My idea is to part the deck out but getting the tractor would be a good backup machine. Share this post Link to post Share on other sites
953 nut 62,535 #2 Posted July 31, 2018 26 minutes ago, Goldnboy said: is there a special lever to disengage hydro to roll That depends on the year it was made. older C-145 have a Sundstrand Hydro and have the push valve, newer ones have Eaton Hydro and no push valve. Dose your hydro oil filter face the rear or to the right hand side? Share this post Link to post Share on other sites
pfrederi 19,069 #3 Posted July 31, 2018 (edited) Eaton hydros do not have a tow valve. Just move it slowly and only for a short distance ...you will probably here a clicking noise when you roll Edit: 1980 could have had Sundstrand but all other years Eaton Edited July 31, 2018 by pfrederi 1 Share this post Link to post Share on other sites
c-series don 10,666 #4 Posted July 31, 2018 Easy way to remember this is: Eaton on the end, Sundstrand on the side. As far as filter placement and how recognize which is which. 1 Share this post Link to post Share on other sites
Goldnboy 1,063 #5 Posted July 31, 2018 I was able to get the engine info. Kohler k321as spec 60373 Share this post Link to post Share on other sites
pfrederi 19,069 #6 Posted July 31, 2018 makes it a l981 - 1984 and s/b eaton 1 Share this post Link to post Share on other sites
shallowwatersailor 3,216 #7 Posted July 31, 2018 It has a metal fender which might mean late '82-'84, but then it may be a replacement metal fender. The brake looks like the linkage is disconnected. Share this post Link to post Share on other sites
