Tach-a-matic 357 #1 Posted July 31, 2018 (edited) Hello All, This is my second Horse, with the first being a 1974 C160, owned from 1997 - 2004. A great tractor, I miss it, but got married and did not have the space at that time to keep it further. Fast forward 14 years(!) to my new 416H with 7xx hours on the meter. This thread will outline the catch-up maintenenance so I can rest at ease knowing its been gone through. The unit had been equipped with a rear discharging deck and put away wet it seems... Clippings trapped inside the wheel behind the hubcap! . The air filter was not as bad as I thought it would be Edited July 31, 2018 by Tach-a-matic 3 Share this post Link to post Share on other sites
Tach-a-matic 357 #2 Posted July 31, 2018 After washing her yesterday New TSC seat required 2 new holes drilled in the ratcheting brackets The Onan looks pretty clean, right? Hold on to that thought! 4 Share this post Link to post Share on other sites
Tach-a-matic 357 #3 Posted July 31, 2018 Looks can be deceiving because tonight, another sizable pile of grass was removed from in between the frame rails and in front ot the hydro unit. Lots of nooks and crannies under the tractor right behind and above the lift arm. After seeing all this and reading up about Onans here I took the engine shroud off. Glad I did... This is what kills Onan's right? Lots of vacuuming and blowing to do tomorrow night. Well at least it is easy to change the filter now! Paul 4 1 Share this post Link to post Share on other sites
cleat 8,330 #4 Posted July 31, 2018 Looks like you are going to have a nice tractor once it is cleaned up. My eyes might be deceiving me but your front wheels look small. What size are they ? Share this post Link to post Share on other sites
JAinVA 4,638 #5 Posted July 31, 2018 Paul, Nice looking horse.It cleaned up well.The grass build up is one of the reasons Onans get such a bad rap.The rear cylinders over heat and the intake seats can get loose.A lot of folks here have modified the belt guard to increase air flow over the rear cylinder.You might want to do a search to see the mods that have been done.While there may be some who think these mods aren't necessary one thing is certain they make monitoring built up and cleaning easier. 2 Share this post Link to post Share on other sites
Tach-a-matic 357 #6 Posted July 31, 2018 8 minutes ago, cleat said: Looks like you are going to have a nice tractor once it is cleaned up. My eyes might be deceiving me but your front wheels look small. What size are they ? I thought so too so just checked and they are 15x6.00-6 Share this post Link to post Share on other sites
Tach-a-matic 357 #7 Posted July 31, 2018 10 minutes ago, JAinVA said: Paul, Nice looking horse.It cleaned up well.The grass build up is one of the reasons Onans get such a bad rap.The rear cylinders over heat and the intake seats can get loose.A lot of folks here have modified the belt guard to increase air flow over the rear cylinder.You might want to do a search to see the mods that have been done.While there may be some who think these mods aren't necessary one thing is certain they make monitoring built up and cleaning easier. thanks. Seeing the fins covered up was quite the eye opener. She runs good and doesn't smoke after 15 mins of light running so hopefully no harm has been done. I do wonder if it all could have been pulled out once the oil filter is off? Will check others mods. Getting the shroud off without damaging the wires coming up from the flywheel was a little tricky - getting it back on wont be fun - I dont want to do this job again soon. This will be a snow machine #1 (it came with a SS that can I see needs a new chain and sprockets ) so it wont be knee deep in grass anymore 1 Share this post Link to post Share on other sites
JAinVA 4,638 #8 Posted July 31, 2018 (edited) I only use my 416h as a snowblower and drawbar tractor to eliminate grass buildup. I use the Kohler powered machines to mow with,. I lost my c120 to a grass build up fire years ago.The sad part is I don't have a nice lawn and just try to keep the weeds at a uniform height. Edited July 31, 2018 by JAinVA 1 Share this post Link to post Share on other sites
cleat 8,330 #9 Posted July 31, 2018 8 hours ago, Tach-a-matic said: I thought so too so just checked and they are 15x6.00-6 You should have 16x6.5-8 Share this post Link to post Share on other sites
Pollack Pete 2,273 #10 Posted July 31, 2018 Nice 416H.I had one with a 2 stage snow blower and cab.Wish I still had it.It's really something the way lawn clippings accumulate on these tractors.Good part of routine maintenance to at least blow them off once in a while.Have fun wth your new toy. 2 Share this post Link to post Share on other sites
Tach-a-matic 357 #11 Posted July 31, 2018 In looking at pics of other 416's there appears to be 2 sizes out there. Maybe it was just a normal production variation? 1 Share this post Link to post Share on other sites
peter lena 9,641 #12 Posted July 31, 2018 you are definitely on the right track to get a base line on your grass storage areas, they are also great mouse housing , stay after them. talking about your r/d mower deck, that is another grass trap that should be regularly scraped out ,and most importantly left upside down in the sun to dry out. too often neglected and never cleaned or serviced , destroys them fast. I also regularly chain cable oil spray mine , letting it soak in the oil with the sun baking it in to the hot metal. ( just the opposed of the life it lives ) , I have no rot or rust , your tractor looks great, good luck with it , pete 1 Share this post Link to post Share on other sites
lynnmor 8,382 #13 Posted July 31, 2018 Just my two cents That nest in the engine looks like a rodent job to me. There should be a pre-filter wrapper over the air filter element. The oil filter is the short one, the longer one is better. Be sure that you have the grommet around the oil filter, the long filter holds it much better. It appears oily under the rat nest, those mounts tend to weep oil and cause buildup of air blocking grime. Replace gasket if needed. You should pull the fuel tank, there might be much debris and rust in the seat mounts. OK, that was six cents 2 1 Share this post Link to post Share on other sites
Tach-a-matic 357 #14 Posted August 1, 2018 tonights work DONE!!! Share this post Link to post Share on other sites
Tach-a-matic 357 #15 Posted August 1, 2018 gonna give these leds a try... Share this post Link to post Share on other sites
lynnmor 8,382 #16 Posted August 1, 2018 Now that is progress! Your tins should fit better next to the oil filter so there isn't a lot of gap between them, then the grommet stays on the outside instead of holding the tins apart. Those LED bulbs might be the ticket, let us know how the work out and your supplier. 1 Share this post Link to post Share on other sites
Tach-a-matic 357 #17 Posted August 1, 2018 (edited) I might have bend the tins some to get a better fit Tried the new bulbs. They seem to be a dime a dozen on eBay but chose these because they were the closest... https://www.ebay.com/itm/PAR36-LED-Landscape-Bulb-9W-900LM-50W-Halogen-Equivalent-6000K-Cool-White/323370106103?epid=7011961495&hash=item4b4a5c3cf7%3Ag%3AhuQAAOSwtPlbW6wb&_sacat=0&_nkw=PAR36+LED+Landscape+Bulb%2C+9W%2C+900LM+50W+Halogen+Equivalent%2C+6000K+Cool+White%2C.&_from=R40&rt=nc&_trksid=m570.l1313 bezels removed new led on left: Halogen exposed, LED covered: LED exposed, Halogen covered: Both LED's installed: Paul Edited August 1, 2018 by Tach-a-matic 1 2 Share this post Link to post Share on other sites
Charles123 12 #18 Posted August 1, 2018 On 7/30/2018 at 9:33 PM, Tach-a-matic said: Looks can be deceiving because tonight, another sizable pile of grass was removed from in between the frame rails and in front ot the hydro unit. Lots of nooks and crannies under the tractor right behind and above the lift arm. After seeing all this and reading up about Onans here I took the engine shroud off. Glad I did... This is what kills Onan's right? Lots of vacuuming and blowing to do tomorrow night. Well at least it is easy to change the filter now! Paul Heat is definitely You're enemy Key cook maintenance should have no problem Share this post Link to post Share on other sites
lynnmor 8,382 #19 Posted August 1, 2018 Photos can be deceiving because the camera adjusts exposure for the prevailing light unless you can set it to the same manual settings for each photo. Is it your opinion that it is much better and well worth the expenditure? Share this post Link to post Share on other sites
Tach-a-matic 357 #20 Posted August 1, 2018 (edited) IMO... For an older vintage tractor the color and quantity of LED lighting is inappropriate. If improving nighttime lighting and daytime visibility are important this is one of the easiest improvements ever and well worth the $40. Edited August 2, 2018 by Tach-a-matic Share this post Link to post Share on other sites
Tach-a-matic 357 #21 Posted August 2, 2018 "You should pull the fuel tank, there might be much debris and rust in the seat mounts" Great suggestion, it definitely needed it Changed the hydro oil and the filter too. Only 3 quarts drained out so that's what was replaced. And the seat strut too... . Share this post Link to post Share on other sites
Tach-a-matic 357 #22 Posted August 3, 2018 On 7/30/2018 at 11:00 PM, JAinVA said: I only use my 416h as a snowblower and drawbar tractor to eliminate grass buildup. I use the Kohler powered machines to mow with,. I lost my c120 to a grass build up fire years ago.The sad part is I don't have a nice lawn and just try to keep the weeds at a uniform height. I will relegate it to the same duty. All that grass in the engine is a ticking timebomb for not only the engine but the house too! Share this post Link to post Share on other sites
rustyoldjunk 127 #23 Posted August 3, 2018 I believe the variation between 6 and 8 inch front wheels on the 300 and 400 series depended on the deck. If I recall correctly the 37 inch deck had to have 6 inch wheels for clearance. Share this post Link to post Share on other sites
peter lena 9,641 #24 Posted August 3, 2018 thank you tech a matic on those headlight bulbs, I plow and blow snow typically at night, for low road traffic , and those lights should really help, also on the good response of this tractor issue, I would magic marker , oil filters , with date and hrs.', helping next service. I would also pre oil filter to lessen a low oil pressure start. pete Share this post Link to post Share on other sites
WHX?? 53,701 #25 Posted August 3, 2018 Nice work goin on here Paul ...keep at it . I did a thread awhile back on led conversion and yours seem much brighter. Check it out and comment if desired. Share this post Link to post Share on other sites
