Countdown To Christmas!
FatJackDurham
520H exhaust bolts sheared off - how hard to fix?
FatJackDurham
I just picked up a 520H where the previous owner had tried to replaced the muffler and sheared off the bolts holding the muffler flanges on. I’m thinking drill and tap. Anyone have suggestions for the thread size, warnings?
Jerry77
Along with all the good advice you will be getting, add one more....patience,,patience,  patience...:twocents-02cents:
WVHillbilly520H
Thread size I believe 5/16"-18, if there is any bolt left sticking up above the port, try welding a nut to it the heat should help release the seized threads as well as something to "wrench" it out with, Jeff.
  • Excellent 3
lynnmor
You might be able to drill deep enough to completely remove the old bolt and still have enough depth to install a longer bolt.  Just be sure that you have a stop collar on the drill bit to prevent excess depth.  After drilling, run a tap as deep as possible for the new bolt.   If you run a small drill thru first, you will be able to determine if this is feasible.
FatJackDurham
THanks.
R. L. Addison
Might check you tube, saw some good work on there last night.
JAinVA
All the advice you are getting is good.If you end up having to install helicoils one advantage is that they are made of stainless steel and will act as a barrier to any further corrosion.A lot of folks turn their noses up at a  heli-coil repair but in fact every aircraft or space craft has them when new.
Edited by JAinVA
Digger 66
Center-punch it
Drill it
Soak it
Heat it
And use a good name brand thread extractor .
The center punch is the key here .I always use my angle grinder to knock it down as flush as I can .
This way :
1) You are not deceived by the thread and can punch exactly in the center of the original hole .
2) The angle grinder will leave the surface slightly concave which is a benefit as well .
If you get as close to dead center as you can , you can use the biggest drill possible .
Good luck !
FatJackDurham
I was able to attach a nut to one of them. Do you really thing welding it will loosen it enough to back out?
953 nut
Welding the nut to the stud will cause electrical currant to flow through the corrosion that is holding the old stud in place. The corrosion is a high resistance material compared to the stud and block so it will heat up and break the corrosion down to a powder and allow the stud to be removed. While it is hot you could also apply some paraffin wax which will run into the threaded area and provide lubrication.
Digger 66
Every time I try this , I get good flow to the nut but the head seems to "sink" all the heat away from the stud leaving me with a melted /deformed nut and hardly any  adhesion to the stud ( especially an aluminum head ).
I'm admittedly no pro welder but it has never worked for me .
Good luck though ....
Edited by Digger 66
cleat
My 2002 F150 had 3 broken exhaust manifold studs and my neighbor welded nuts to the studs and they came out.
I think all 3 were below level as well. The weld does not stick to the aluminum.
It took a lot of heat as the aluminum kept drawing the heat away.
However, in this case I think the bolts were fatigued and not actually stuck.
Cleat
groucho
I'm new here so please bare with me, I was wondering if any one would know the belt size of a 1985 series 211-3 transmission drive belt. I don't know how to start a conversation of my own.
Digger 66
Welcome to Red Square !
Edited by Digger 66
groucho
thank you bud!!
FatJackDurham
Groucho - Good luck. Keep trying.
Everyone else - OK! I'll break out the TiG welder tonight and try to weld that old nut on. It would be nice if that fixed it. It took just under two hours to drill out that other bolt. I tapped it with a 5/16-18 tap, but I'm wondering if I shouldn't just drill it out and heli-coil it with stainless threads, as suggested.
If this welded nut works, then I'll have just one more bolt to drill out. In a fit of optimism, I already ordered the muffler and gaskets.
FatJackDurham
Welding didn’t work, I couldn’t get the bolt head to melt at the same time as the nut. I wonder if it would have worked with a higher quality nut?
anyway, nice try but I’m going to have to John McCain it, drill baby, drill.
FatJackDurham
Drilled tapped and coiled. Waiting for the new muffler. What type of bolts should I use? Stainless? Or high grade steel?
cleat
I would use a grade 5 with lots of never seize.
Stainless is weaker and grade 8 would be difficult to drill out if it broke again.
You could use studs and nuts as well.
953 nut
:WRS:
Your best bet will be to start a new post for any further information you may need.
This manual should be helpful.
