Pogo 57 10 #1 Posted July 11, 2018 Went to replace fuel line on my 76 B100. The bung and fuel shutoff came out of the tank bottom. How do you put it back on that little hole in the tamk bottom? Is there a secret? Is there an alterative part to replace this poorly engineered design? It came out of the tank very easily just by lifting the tank off? Thanks so much. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,005 #2 Posted July 11, 2018 That bushing is still used today by almost every manufacturer. Get a new one and put a smear of Vaseline on it and work it into the tank. Then do the same thing with the valve. https://www.partstree.com/parts/toro/parts/46-6560/ Garry 2 Share this post Link to post Share on other sites
ebinmaine 77,365 #3 Posted July 11, 2018 26 minutes ago, Pogo 57 said: there a secret? Is there an alterative part to replace this poorly engineered design? It came out of the tank very easily just by lifting the tank off 11 minutes ago, gwest_ca said: Get a new one @Pogo 57 that wasn't really all that much of a design flaw... When it was new. Your biggest problem there is the age of the grommet. I've run into this exact same scenario myself and probably experienced a similar level of frustration and confusion. When you buy a new one it will be flexible and pliable and will pop right in. Note that I called out Gary's quote of "get a new one." That might be the most important set of words in his reply. As to the shut-off valve being replaced, even if yours seems perfectly fine and is not leaking I would throw another one in there. They're only a few bucks and it could save an eventual headache. The rubber o-ring in that is likely the same age as the dried out rubber that the grommet is made of. 3 Share this post Link to post Share on other sites
clueless 3,348 #4 Posted July 11, 2018 You can buy a new bung and shut off cheap on ebay.To install, put a little Vaseline, 3 in 1 oil, bearing grease, are motor oil around the nipple of the bung and shutoff valve, push the shut off half way into the bung then put the bung in the tank hole and push the shut off valve in, should pop right in. You will probably get another 42 years out of this poorly engineered design . 3 Share this post Link to post Share on other sites
rmaynard 16,873 #5 Posted July 11, 2018 4 hours ago, Pogo 57 said: ...this poorly engineered design... I would not go so far as to say it was a poorly designed part. My 1977 B-100 still has it's original grommet and valve and it does not leak. I'd say that is a pretty good design in my opinion. 3 1 Share this post Link to post Share on other sites
Pogo 57 10 #6 Posted July 11, 2018 Ok guys, took the parts to my local Amish small engine shop and the guy went to the shelf and pulled both parts. 10 bucks and on my way to finishing up this job. 4 1 1 Share this post Link to post Share on other sites
Tractor boy 239 #7 Posted July 11, 2018 I don’t know the Amish has gas engines! Share this post Link to post Share on other sites
rjg854 12,847 #8 Posted July 11, 2018 How do you think they generate their electricity or the air they use for their tools The milk they get from the cows must be refrigerated if it sold to a milk producer. 1 1 Share this post Link to post Share on other sites
