953 nut 70,562 #201 Posted November 4, 2018 6 hours ago, fast88pu said: upgrade time Kyle, you aren't old enough to remember a TV program called the Six Million Dollar Man ( 1974 to 1978). The opening lines of the show came to mind when I saw this. Gentlemen we can rebuild him We have the technology We have the capability to make the worlds first bionic man Steve Austin will be that man Better than he was before Better, Stronger, Faster source: https://www.lyricsondemand.com/s/sixmilliondollarmanlyrics/sixmilliondollarmanopeninglyrics.html Share this post Link to post Share on other sites
19richie66 17,950 #202 Posted November 11, 2018 When you get bored and your mind wanders 1 4 Share this post Link to post Share on other sites
fast88pu 3,402 #203 Posted November 11, 2018 3 minutes ago, 19richie66 said: When you get bored and your mind wanders That's awesome. Out of metal? Share this post Link to post Share on other sites
19richie66 17,950 #204 Posted November 11, 2018 I was working on a couple of cup decals and threw it together 2 Share this post Link to post Share on other sites
Tractorhead 9,218 #205 Posted November 11, 2018 You build a pretty cool tractor. I'm curious what is next ! 👍 1 Share this post Link to post Share on other sites
Tractorhead 9,218 #206 Posted November 12, 2018 (edited) Where is the Fueltank from ? is it selfmade part ?? I like it 👍😎 Edited November 12, 2018 by Tractorhead Share this post Link to post Share on other sites
fast88pu 3,402 #207 Posted November 13, 2018 21 hours ago, Tractorhead said: Where is the Fueltank from ? is it selfmade part ?? I like it 👍😎 Ebay Share this post Link to post Share on other sites
Tractorhead 9,218 #208 Posted November 13, 2018 Thanks for info, i'm thinkin about to use it maybe as Hydraulictank. Share this post Link to post Share on other sites
fast88pu 3,402 #209 Posted November 14, 2018 Pipe dreams 1 2 1 Share this post Link to post Share on other sites
Pullstart 71,542 #210 Posted November 15, 2018 Going for compounds? Share this post Link to post Share on other sites
fast88pu 3,402 #211 Posted November 18, 2018 Had some fun welding today. 1st time welding stainless steel. NEW exhaust manifold is all made. 100% 304 stainless now. Just have to Polish it up now. And a old vs new manifold photo. 2 3 Share this post Link to post Share on other sites
Pullstart 71,542 #212 Posted November 20, 2018 How many horsepowers will that add? Or was design #1 like a capacitor keeping extra boost energy on tap? 1 Share this post Link to post Share on other sites
fast88pu 3,402 #213 Posted November 20, 2018 5 hours ago, pullstart said: How many horsepowers will that add? Or was design #1 like a capacitor keeping extra boost energy on tap? Lol. Bout 3.99 hp 1 Share this post Link to post Share on other sites
fast88pu 3,402 #214 Posted November 20, 2018 All polished up now 3 3 Share this post Link to post Share on other sites
fast88pu 3,402 #215 Posted November 25, 2018 NEW header is all mounted an it turning blue and gold 4 Share this post Link to post Share on other sites
fast88pu 3,402 #216 Posted December 3, 2018 This past weekend I ran my towns local tractor parade with it. I was asked lots of questions about it and had a lot of interest in it by all ages. 3 Share this post Link to post Share on other sites
Tractorhead 9,218 #217 Posted December 3, 2018 It seems to me, you did it Wig welded? How was your experiences in Stainless steel welding after that? Found it hard or was it more simple in compare to Aluminum WIG welding? Looks pretty good! Share this post Link to post Share on other sites
fast88pu 3,402 #218 Posted December 3, 2018 1 hour ago, Tractorhead said: It seems to me, you did it Wig welded? How was your experiences in Stainless steel welding after that? Found it hard or was it more simple in compare to Aluminum WIG welding? Looks pretty good! That is all mig welded with 308 wire. It takes a lot of heat and I didn't use the tri blend of gas on it so harder yet. Now I have a tig welder for next time I weld stainless. Aluminum is much harder to weld because of spool gun use. 1 Share this post Link to post Share on other sites
Tractorhead 9,218 #219 Posted December 4, 2018 Ah ok, i thought you did it Wig welding. i try WIG last time on Aluminum, in my experience i found it's more complicated than Mig, but the result looks massive better. So Wig just needs more training to get clean seam. Thanks for your info. Share this post Link to post Share on other sites
fast88pu 3,402 #220 Posted December 4, 2018 2 hours ago, Tractorhead said: Ah ok, i thought you did it Wig welding. i try WIG last time on Aluminum, in my experience i found it's more complicated than Mig, but the result looks massive better. So Wig just needs more training to get clean seam. Thanks for your info. The original plan was to tig it but the rods didn't show up in time for me. So that will be next time. 1 Share this post Link to post Share on other sites
Pullstart 71,542 #221 Posted December 4, 2018 Stefan, I believe there may be a translation barrier here... TIG for us is Tungsten Inert Gas, it has a hand held torch with the shielding gas and an electrode, with hand held filler rod. MIG is Metal Inert Gas, it has the hand held gun with wire feed filler, sometimes also with flux core (shielded and gasless) wire. what is WIG, I’m assuming that’s our TIG? 1 Share this post Link to post Share on other sites
fast88pu 3,402 #222 Posted December 4, 2018 1 hour ago, pullstart said: Stefan, I believe there may be a translation barrier here... TIG for us is Tungsten Inert Gas, it has a hand held torch with the shielding gas and an electrode, with hand held filler rod. MIG is Metal Inert Gas, it has the hand held gun with wire feed filler, sometimes also with flux core (shielded and gasless) wire. what is WIG, I’m assuming that’s our TIG? Tig and wig are the same 1 Share this post Link to post Share on other sites
Pullstart 71,542 #223 Posted December 4, 2018 32 minutes ago, fast88pu said: Tig and wig are the same Got it, I had never heard that! Share this post Link to post Share on other sites
fast88pu 3,402 #224 Posted December 7, 2018 Header is all warped up now to hold heat in 1 2 Share this post Link to post Share on other sites
fast88pu 3,402 #225 Posted December 11, 2018 I finally got a chance to play with my tig welder and make my exhaust. 2.5" 304 stainless with header wrap on it for heat. Lots of stuff to try snaking 2.5" pipe around and out of the way. 3 4 Share this post Link to post Share on other sites
