MalMac 1,334 #1 Posted July 4, 2018 Was just curious as to what brand of points the members are using. Like everything else out there things are becoming more cheaply made. It’s getting time for point replacement in a couple of engines. I have used a Kohler branded points and have had good ones and junk ones. Same with some off brand ones. Best luck I have had was the Blue Standard ones but even those have gotten cheaper. So what say you members, what brand of points you ya using? 1 Share this post Link to post Share on other sites
lynnmor 8,549 #2 Posted July 4, 2018 I don't know what kind of failures you are having with the points. If you are getting a lump on on side and a divot on the other, replace the condenser. If they have about the same wear on both sides, keep that condenser, a new one might not be as good. 3 Share this post Link to post Share on other sites
Achto 30,847 #3 Posted July 5, 2018 12 hours ago, MalMac said: So what say you members, what brand of points you ya using? They have changed to type of material that points are made of, the new stuff is just not the same. I try to save my old points when ever I can. 30 yr old points seem to last 30+ yrs. New points last about 5yrs if your lucky. 1 2 Share this post Link to post Share on other sites
