Pullstart 69,874 #176 Posted May 5, 2021 Does this engine have a fuel pump? What’s left... electrical? Share this post Link to post Share on other sites
19richie66 17,870 #177 Posted May 5, 2021 7 hours ago, pullstart said: Does this engine have a fuel pump? What’s left... electrical? Fuel pump is just under the front of the air cleaner. Since the engine is magneto ignition, I just need battery power to crank it over for a test run. Just want to test it/the hydro and makes sure it all works. I’ll hopefully make the wiring harness next. I want to use the push button starter and all original controls on it if I can. 5 1 Share this post Link to post Share on other sites
19richie66 17,870 #178 Posted May 8, 2021 (edited) Testing 👍 Edited May 8, 2021 by 19richie66 6 3 2 Share this post Link to post Share on other sites
19richie66 17,870 #179 Posted May 8, 2021 New belt cover. Still have a little tweaking to do. 3 8 Share this post Link to post Share on other sites
PeacemakerJack 10,946 #180 Posted May 8, 2021 Exciting stuff Richie😎 2 1 Share this post Link to post Share on other sites
ebinmaine 78,516 #181 Posted May 9, 2021 Absolutely Excellent. 1 Share this post Link to post Share on other sites
19richie66 17,870 #182 Posted May 9, 2021 2 minutes ago, ebinmaine said: Absolutely Excellent. Thanks Eric! Share this post Link to post Share on other sites
ebinmaine 78,516 #183 Posted May 9, 2021 4 minutes ago, 19richie66 said: Thanks Eric! You're welcome. Check YouTube for my other comment.... 1 Share this post Link to post Share on other sites
19richie66 17,870 #184 Posted May 9, 2021 4 minutes ago, ebinmaine said: You're welcome. Check YouTube for my other comment.... I saw it. Truly humbled by it. Factory look is what I’m after. 2 1 Share this post Link to post Share on other sites
Pullstart 69,874 #185 Posted May 9, 2021 That 12 second clip... is that Tesla mode auto driving? 3 Share this post Link to post Share on other sites
19richie66 17,870 #186 Posted May 9, 2021 (edited) 5 hours ago, pullstart said: That 12 second clip... is that Tesla mode auto driving? cruise control Edited May 9, 2021 by 19richie66 1 Share this post Link to post Share on other sites
19richie66 17,870 #187 Posted May 19, 2021 (edited) In keeping up with the deception, cut the stick shift stick off and welded it to the motion control lever. When the plate is installed and a small “boot” made, it should look like a manual Edited June 14, 2021 by 19richie66 6 8 Share this post Link to post Share on other sites
ebinmaine 78,516 #188 Posted May 19, 2021 I like it. Sleeper Hydro. 2 1 Share this post Link to post Share on other sites
Pullstart 69,874 #189 Posted May 22, 2021 Genius! So creative, Richie! 1 Share this post Link to post Share on other sites
Handy Don 16,409 #190 Posted May 22, 2021 (edited) On 5/2/2021 at 7:52 PM, 19richie66 said: Not on a hydro. You would need to get into the valving and relief springs/settings to increase flow. I prefer to leave it alone. I’ll just be happy if it moves. Larger diameter tires would give you something but nothing earthshaking! Swapping out "H" and in "HC" gears in the transaxle can also add another 1+ mph--but a lot of work and $$ for a small gain. Your creativity and craftsmanship are simply awesome. Thanks for letting us follow along. Edited May 22, 2021 by Handy Don 1 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #191 Posted May 22, 2021 7 hours ago, Handy Don said: Larger diameter tires would give you something but nothing earthshaking! Swapping out "H" and in "HC" gears in the transaxle can also add another 1+ mph--but a lot of work and $$ for a small gain. Your creativity and craftsmanship are simply awesome. Thanks for letting us follow along. And like putting on 30 inch tall tires, wouldn't that make a hydro faster? I heard the 520 are a bit faster, to they have different gearing? 1 Share this post Link to post Share on other sites
19richie66 17,870 #192 Posted May 22, 2021 (edited) 1 hour ago, Maxwell-8 said: And like putting on 30 inch tall tires, wouldn't that make a hydro faster? I heard the 520 are a bit faster, to they have different gearing? I think the 520HC was faster but like mentioned only by maybe 1mph. Too much work for me at this point. It will be quick enough for her. I may go just a little taller with the tires when the time comes. Want to get everything figured out first before teardown and paint. Edited May 22, 2021 by 19richie66 4 3 Share this post Link to post Share on other sites
19richie66 17,870 #193 Posted May 22, 2021 8 hours ago, Handy Don said: Your creativity and craftsmanship are simply awesome. Thanks for letting us follow along. Thanks for following along........I’m humbled and appreciate the comments. 1 4 Share this post Link to post Share on other sites
PeacemakerJack 10,946 #194 Posted May 22, 2021 It is coming along nicely Richie—love the disguised gearshift knob! 3 1 Share this post Link to post Share on other sites
Handy Don 16,409 #195 Posted May 22, 2021 11 hours ago, Maxwell-8 said: I heard the 520 are a bit faster, to they have different gearing? There was thread not long ago that discussed H vs HC gearing (and some other models as well) I remember that it was the short-lived 520-HC ('88-89) that was a bit faster. Same Eaton 1100 as the "H" but its transaxle was geared a bit higher. If I recall correctly, it was 7.5 max vs. 5.6 on the H (?) If you could fit 30" tires (?) and kept your "regular" transaxle it'd up the top speed by 30% -- 5.6 on the 23's to 7.3 mph. I'm sure a "road gear" would be neat for some folks that travel on smooth surfaces, but for me the current max is bouncy enough! 2 2 Share this post Link to post Share on other sites
19richie66 17,870 #196 Posted May 23, 2021 Tires on it now are 27” tall, 4” taller than the 520 stock tires. Should roll around ok. 4 Share this post Link to post Share on other sites
Handy Don 16,409 #197 Posted May 23, 2021 4 minutes ago, 19richie66 said: Tires on it now are 27” tall, 4” taller than the 520 stock tires. Should roll around ok. It'll be quick, that's for sure! 2 Share this post Link to post Share on other sites
19richie66 17,870 #198 Posted May 23, 2021 Think it might just make it to the Big Show 2 6 Share this post Link to post Share on other sites
19richie66 17,870 #199 Posted May 28, 2021 (edited) Throttle & choke levers came in today. Those are installed, cables hooked up and adjusted. Also made a plate for the solenoid to mount to. Wiring is next. Made a harness from an Xi harness I had. Repositioned wires to the correct terminals and Ohm tested good. Edited May 28, 2021 by 19richie66 4 1 Share this post Link to post Share on other sites
19richie66 17,870 #200 Posted June 13, 2021 (edited) List is getting smaller.......Got the foot plates shaped and bolted up. Finished the wiring, solenoid plate and the side cover. Had to rivit an upper mounting bracket on the belt cover till an aluminum magician can work his magic. It’s getting excited to go to the show. Edited June 13, 2021 by 19richie66 7 1 1 Share this post Link to post Share on other sites
