MarkS 122 #1 Posted July 2, 2018 Hello, I am looking for a horse to mow a very huge yard. I think a 60" deck would be needed, but im not sure of any pros or cons to WH 60" decks? As far as a tractor for a 60' deck, I think I would have to be looking at either a 520-h or a D-1(60,80,200). Between the two of those, what would be the better tractor? Also, I'll take any general recommendations on the best possible mowing setup! Thanks! Share this post Link to post Share on other sites
Tractor boy 239 #2 Posted July 2, 2018 Well the d would be more powerful while the 500 series would be the weaker option. The d’s are a pain to work on while the 500’s are fairly easy. I don’t think the 500’s have 3 points on them while the d’s do. Personally considering these factors I would choose the 500 series as I don’t need the 3 point and don’t really need the power. I also wouldn’t want to pay the extra dough for that. I would take the 500 for about 1000 dollars or less then add extra for any implements or extras. Also welcome to one of the best forums! -Tractorboy 1 Share this post Link to post Share on other sites
Sparky-(Admin) 25,473 #3 Posted July 2, 2018 10 acres! Neither. Sounds like you need a good quality zero-turn. A 520H no matter the deck size is only going to be able to go 4ish miles per hour, you’ll be mowing foooorevvvver! 11 1 Share this post Link to post Share on other sites
WHX?? 56,795 #4 Posted July 2, 2018 I would go with the 520 and a 60 incher although a 60 is a beast and have been known to rip 520 frames. I was going to suggest that too @Sparky but I'm tryin to keep the guy in Red! You could always get a Toro Z and put decals on it! 3 1 1 Share this post Link to post Share on other sites
MarkS 122 #5 Posted July 2, 2018 15 minutes ago, Sparky said: 10 acres! Neither. Sounds like you need a good quality zero-turn. A 520H no matter the deck size is only going to be able to go 4ish miles per hour, you’ll be mowing foooorevvvver! Does the D series go any faster than the 520? Share this post Link to post Share on other sites
squonk 46,773 #6 Posted July 2, 2018 Farmall Cub, A or Allis B or C with belly mowers. 5 2 Share this post Link to post Share on other sites
MarkS 122 #7 Posted July 2, 2018 3 minutes ago, squonk said: Farmall Cub, A or Allis B or C with belly mowers. I honestly threw around that idea. They are nice machines, and you can find them at a pretty decent price. It just thought it would be awesome to have a WH with a 60" deck. It makes a good excuse for me! Haha 2 Share this post Link to post Share on other sites
ClassicTractorProfessor 5,455 #8 Posted July 2, 2018 4 minutes ago, squonk said: Farmall Cub, A or Allis B or C with belly mowers. Agreed...either one of those or a small tractor with a brush beater on the back...used to have a Ford 2n with a beater that I regularly mowed 11 acres with...worked great 2 Share this post Link to post Share on other sites
MAD MARK 74 #9 Posted July 2, 2018 You can be a wheel horse fanboy all you want, but the answer to mow 10 acres will never be a Wheel Horse. Unless you're retired and that's all you want to do. 8 1 2 Share this post Link to post Share on other sites
MarkS 122 #10 Posted July 2, 2018 Okay, the 10 acre lawn for wheel horse is out of the question! I have a few different lawns I mow for people, it usually works out good where they buy me the tractor and I use it to mow for them there. Is 3-5 acres a reasonable amount to handle with a wheel horse? Share this post Link to post Share on other sites
Cee245 853 #11 Posted July 2, 2018 With the total amount of acres you need to mow, I don't think wheel horse is the best tractor for that. My brother has an Exmark commercial mower zero turn for his yard. Works great. I think Exmark is a Toro brand? So it's loosely related to wheelhorse. Hahaha 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #12 Posted July 3, 2018 I mowed 2.5-3 acres with a 48" deck on my 520H for 15-17 out of the 20 years I have owned one, with a 60" deck I'm sure mowing would go faster than it did for me, but like others have said a ZTR would be the way to go for faster mowing of large tracts, I have moved on to a sub compact 4x4 with 60" deck and what used to take 3+ hrs now 1.5hr (lots of hills) and use the for trimming close to the house ect, but a CUB LOW BOY would be a good option also, Jeff. 5 Share this post Link to post Share on other sites
Tractor boy 239 #13 Posted July 3, 2018 I know the scag turf tiger or patriot is a very nice z turn. 1 Share this post Link to post Share on other sites
lynnmor 8,836 #14 Posted July 3, 2018 1 hour ago, MarkS said: Okay, the 10 acre lawn for wheel horse is out of the question! I have a few different lawns I mow for people, it usually works out good where they buy me the tractor and I use it to mow for them there. Is 3-5 acres a reasonable amount to handle with a wheel horse? That's what I am mowing with a 520H and a 60" deck. I am actively seeking a good low hour zero turn. If all the mowing were clear and straight, the zero would not have a great advantage. I mowed this week with a disposable 42" Troy-Bilt, because of ignition module and relay socket failures, and with trimming it took me 7 hours which is more than twice as long. 1 Share this post Link to post Share on other sites
SPINJIM 1,997 #15 Posted July 3, 2018 Zero turns are faster, not because they can move any faster than a 520H, but because the blades rotate almost three times as fast. That allows the ZT mower to move faster over heavy grass. If you go with a ZT, get a 'commercial' duty one to handle 10 acres. The 'homeowner' ones won't hold up as long. Good luck, Jim 1 2 Share this post Link to post Share on other sites
ronhatch 410 #16 Posted July 3, 2018 (edited) Ford Golden Jubilee preferably with a 72" mower or maybe with a 5 gang reel mower. There was a gentleman farmer across the road from where I grew up in the 50's that had a beautiful massive,15 acre front yard. He pulled a 5 gang mower using a shorten AA Ford truck. Everything was removed from the cowling back except for a single seat which was located over the rear axle. Hopefully he had a seat belt because he had to be going 20 MPH with those reel mowers Edited July 3, 2018 by ronhatch 1 Share this post Link to post Share on other sites
ebinmaine 79,077 #17 Posted July 3, 2018 My first and biggest question is: What is the terrain in this field?? Here in the Northeast there's a lot of very wavy bumpy land. That would slow down Any machine. I like the idea the older machines but the Commercial ZTR is likely your "fastest" way... Though not the way I'd go. Gotta be a classic. If the ground is reasonable... Gang setups work great. 12 - 15 foot wide cutting path..... Share this post Link to post Share on other sites
Achto 31,886 #18 Posted July 3, 2018 If you like the idea of mowing with a I would suggest a 520HC and a 9'8" gang set up. https://www.northerntool.com/shop/tools/product_112395_112395?cm_mmc=Google-pla&utm_source=Google_PLA&utm_medium=Lawn %2B Garden > Lawn Mowers > Gang Reel Mowers&utm_campaign=Pro Mow&utm_content=250033&gclid=EAIaIQobChMIoKitvN6C3AIVRYjVCh0h8Qh0EAQYAiABEgKYavD_BwE I like the fact that the picture on their site shows it hooked to a . Good call Northern Tool !! 4 3 1 Share this post Link to post Share on other sites
clueless 3,403 #19 Posted July 3, 2018 Once you go ZT, you'll never go back . Share this post Link to post Share on other sites
ebinmaine 79,077 #20 Posted July 3, 2018 4 hours ago, clueless said: Once you go ZT, you'll never go back . Well, you really don't have to go back. You can just turn in really really small circles. 8 Share this post Link to post Share on other sites
CasualObserver 3,416 #21 Posted July 3, 2018 14 hours ago, SPINJIM said: Zero turns are faster, not because they can move any faster than a 520H, but because the blades rotate almost three times as fast. That allows the ZT mower to move faster over heavy grass. Like the gang mowers above, a zero turn is built to mow... that's it's only real job. The blade speed on an average lawn mower is 3000-4000 fpm... whereas the blade speed on my Gravely zt is running around 17,000 fpm allowing me to mow as fast as I can move forward. If you're mowing 10 acres... or even just 3-5 of the 10, I think I'd still look for a good Z. With that kind of ground to cover, you definitely want to look for a commercial grade unit. Homeowner grade models usually run about 7mph same as high gear on any garden tractor.... if you go up to a commercial unit you can get speeds in the 12-16mph range. My family has a commercial 60" Gravely at the Christmas tree farm and that baby mows about 8 acres of grass beautifully at 15 mph.. and with the suspension seat, the ride on that at 15 mph is better than my 7 mph on my homeowner Gravely model. 6 Share this post Link to post Share on other sites
Jrblanke 958 #22 Posted July 3, 2018 I just sold a cub tractor for $2100 w/ a 60" woods belly mower. I was surprised at how cheap those things were. You can also raise ithe deck higher than a 520 would raise a deck, and even though its rated at 14Hp, there are 4 cylinders and has more gearing and torque. If you HAD to use a WH I think I would do some research on pull behind/wing mowers and then obviously you would want a 48"+ deck on the 520. To me, though 10 acres is a a lot of property to cut with something smaller than 60". I guess it depends on how much time you want to spend on the mower and how often you want to cut it. Here is a mowing calculator you can use. AT 4 mph and a 60" cut, you can do 2.18 acres per hour. S0 it would take you around 5 hours to cut not counting refuel time. https://www.landscapecalculator.com/calculators/mow Interesting question to ponder! I've never had to think about this. 1 Share this post Link to post Share on other sites
FatJackDurham 318 #23 Posted July 3, 2018 If its flat, I agree with the zero turn. I believe the old GT-14 is one of the faster models and it can have a 3-pt. When you say 60", I assume that means a tow behind? I didn't know they made a 60" that goes under the tractor, or if they do, it probably would crack the frame after a while. Share this post Link to post Share on other sites
pfrederi 20,629 #24 Posted July 3, 2018 This rig mows at least that and a lot of it is not very smooth i think a non commercial Z turn would beat you and itself to death on the areas I mow. More importantly the tractor cost me 1200 the deck 1500.and i have been using her for 12-13 years now. 72 inch New Holland finish mower 1951 Case VAC rate at 21hp on the belt 19 drawbar. 6 2 Share this post Link to post Share on other sites
ebinmaine 79,077 #25 Posted July 3, 2018 3 minutes ago, pfrederi said: 72 inch New Holland finish mower 1951 Case VAC Yeah...... 1 Share this post Link to post Share on other sites
