Al C. 1,474 #1 Posted June 30, 2018 Hauling brick for a new fire pit - no sweat! (1967 Wheel Horse 1067.) 10 Share this post Link to post Share on other sites
Pollack Pete 2,273 #2 Posted June 30, 2018 Nice Horse.Neat fire pit.Where did you buy the pit? Share this post Link to post Share on other sites
953 nut 67,330 #3 Posted June 30, 2018 8 hours ago, Al C. said: brick for a new fire pit The things people will do to get a little seat time! Share this post Link to post Share on other sites
Al C. 1,474 #4 Posted June 30, 2018 The pit is built with two galvanized steel joining rings for culvert drainage pipe. The smaller ring is 36 inches in diameter. The larger ring is 48 inches. I’m going to fill the void between them with old brick and gravel (topped off with gravel). The outside of the pit will always stay “cool”. The floor of the pit is two sheets of galvanized ducting steel riveted together and cut round. Will look like this when done ... 3 Share this post Link to post Share on other sites
squonk 47,337 #5 Posted June 30, 2018 Might want to wipe down the galvanizing. The fumes when first heated could be nasty. Share this post Link to post Share on other sites
Charles123 12 #7 Posted September 9, 2018 OK here we go haven't 19 to SK486 it has A Ignition update to Electronic Ignition no points plastic flywheel fan The nubs Broken off no grass Screen Have new ones on the old Blower shroud Do you have to open it up to make it fit the new plastic grass Screen Share this post Link to post Share on other sites
Charles123 12 #9 Posted September 10, 2018 What A-day yesterday I'll tell you I got up I have been laying on my glasses all night long and I think I seen crooked all day long Been having problems with the Fan and grass green On my SK486 already was ready to open it up to make the Grass screen work well after closer inspection all I had to do is bump a little metal around the make it work Then noticing that the kill a circuit had 3 spices in itIt's been a while since I've gone back through something than taking care of what someone else didn't have the knowledge of bolts that are going in the lock nuts that are not protruding through So they're not locked Just flat out bolts that are not tightened Front axle pin was loose so I had put a new actual under it I will say the tractor was nice and shiny when I bought it had just been painted Stunk my garage up for 2 weeks I don't believe any harder in the pain Motor was posted then rebuild it run strong let's hope I don't mind doing the rest for But I wanna do It One timeDo write a first Time It Should last other 30 years New spindles wheel bearing Wiring get it all back Together then Take it apart and paintedThat's the planWell show pictures later😂😂😎 1 Share this post Link to post Share on other sites
Charles123 12 #10 Posted September 10, 2018 So green on Kohler motors I haven't fell from tree yet🤣🙄😎😏 Share this post Link to post Share on other sites
Charles123 12 #11 Posted September 10, 2018 Oh yes Upper steering shaft Bushing in the console lower support Was broken half Bush and the steering wheel column was Waller Out when people get on the tractors and Use the steering wheel The collar comes loose From theshaft then it all goes downhill from there It is crazy but I'm not bored😃😃😎 Share this post Link to post Share on other sites
