bo dawg 536 #1 Posted June 29, 2018 (edited) Does the fuel pumps on the Onans act up before going completely bad? The engine will run great for a few mins or may run for 1/2 hour or longer, and then it will shut down like turning the key off. Hard to get back started again. But theres always gas in the filter every time I look to see. Edited June 29, 2018 by bo dawg Share this post Link to post Share on other sites
Shynon 7,491 #2 Posted June 29, 2018 Are you sure it's the fuel pump, mine would shut off and I found it to be a bad 9 pin connector. Next time it happens open the hood and wiggle the 9 pin connector and try starting it. 3 Share this post Link to post Share on other sites
bo dawg 536 #3 Posted June 30, 2018 No I’m not sure that’s why I was wondering how a fuel pump acts before it dies. Share this post Link to post Share on other sites
cleat 7,659 #4 Posted June 30, 2018 Failing ignition module could also cause this. 4 Share this post Link to post Share on other sites
Cee245 846 #5 Posted July 2, 2018 Have you done any recent maintenance to your tractor? I replaced the ignition coil to fix an identical issue on my 97 416h. It has the "little brother" p216 Onan compared to the 520's p220 Onan. After replacing the ignition coil. My 416 still shut down after mowing on warm days. THAT problem was I forgot to reinstall the heat shields covering the exhaust thus causing a vapor lock. Good luck Cory 1 Share this post Link to post Share on other sites
lynnmor 8,076 #6 Posted July 2, 2018 These things get heat sensitive with age. Next time you have a shutdown or no start, check the spark immediately, because it may begin to function as soon as the temperature drops. Just stick a spark plug wire on a spare plug for a quick test. 1 Share this post Link to post Share on other sites
bo dawg 536 #7 Posted July 2, 2018 It was running bad, had to choke it to run so I took top of carb off and cleaned it out, full of crap. Now it runs really good at high and low idle but now I have this this problem. In my previous post about the carb issue, I stated that before I took the carb apart I had the key just in run position (not running) to see if lights would work and when I turned key back off it made a loud like back fire noise. Scared the crap out of me, and done it a couple more times when I would repeat turn key on turn key off. I was scared to do it. Eventually it quit doing it and then I took carb apart. Share this post Link to post Share on other sites
lynnmor 8,076 #8 Posted July 2, 2018 The ignition module (trigger), that I linked to above, interrupts current to the coil to cause a spark, the key switch will cause a brief interrupt as well causing the spark plugs to fire. See page 8-2 for testing ignition. manual Share this post Link to post Share on other sites
cleat 7,659 #9 Posted July 2, 2018 I wonder if that is why Onan puts a condenser on the positive terminal of the coil, to prevent this. One of my 520's did this until I replaced the condenser and it has never done it since. Share this post Link to post Share on other sites
lynnmor 8,076 #10 Posted July 3, 2018 (edited) 3 hours ago, cleat said: I wonder if that is why Onan puts a condenser on the positive terminal of the coil, to prevent this. One of my 520's did this until I replaced the condenser and it has never done it since. I think that the condenser is for radio noise suppression, but if one is shorted internally, it would cause problems. That is a good theory, and maybe it would help with misfires. I just looked at replacing mine because of rust and couldn't believe that 99 cent part is $15.00 plus shipping now. Edited July 3, 2018 by lynnmor Share this post Link to post Share on other sites
Cee245 846 #11 Posted July 3, 2018 It really sounds like you need to take the carb completely off and take it all a part and clean every port. I've had to do that several times with the Nikki carbs.seem very temperamental. The carbs on these Onans really need to be clean to run properly. Cory 2 Share this post Link to post Share on other sites
bo dawg 536 #12 Posted July 12, 2018 I took a few mins with the tester today and just done a couple volt checks at battery and then rectifier and coil. Since I'm not much of an electrical person, I think theres an issue. With the tractor off I have good volts at battery and same at the one side of coil, but the other side of coil is almost nothing. Running I get same results with other side of coil low voltage. Now I did the same check with my other 520 that I have, which is a couple years older but same hook up. I have good voltage in/out at both post on coil. So does this mean the coil is bad? I don't see a condenser. Share this post Link to post Share on other sites
lynnmor 8,076 #13 Posted July 12, 2018 The ignition testing procedure is in the manual. The condenser is mounted on the air cleaner mount and connected to the + side of the coil, just follow the wire. 1 Share this post Link to post Share on other sites
bo dawg 536 #14 Posted July 15, 2018 I can not find a condenser on this thing. Both wires go down in under shroud, is that where it is? Have to pull engine cover? Share this post Link to post Share on other sites
