drn441 11 #1 Posted June 24, 2018 I have the transaxle out of my 310-8 because it was leaking all over the garage floor.. when I pulled the drain plug I got a lot of water and milky oil out of it so I want to open up the case and clean everything up and replace all of the seals... Only problem is I'm not sure what model transaxle I have to order parts.. the model number of the tractor is no longer there...The only identification I have is sticker on the transaxle that reads (Uni-Drive Pat. No. 2988185).. also the engine is a kohler magnum 10. any help would be great thanks Dan Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,149 #3 Posted June 24, 2018 According to the records you most likely have 1" diameter axles but there are exceptions. Click on the pictures If it axles are 1-1/8" diameter this trans is from the same time period. The 2988185 is the patent number. If the Kohler spec number and serial number are legible post those. Sometimes a model can be ID'd using them. Garry Share this post Link to post Share on other sites
953 nut 65,237 #4 Posted June 25, 2018 Before you buy seals you should check the axles to see if there is any play, up/down or front/back. If there is any play then bad bearings caused the seals to fail. This thread is a must read for you. 1 Share this post Link to post Share on other sites
stevasaurus 23,662 #5 Posted June 25, 2018 If you have 1" axles, you have the Wheel Horse #110996 transmission. It has the hi/low selection and the differential is a 4 pinion differential. You are going to want to open up the transmission and clean it out. You probably don't have any bad gears, but like Richard said, you may have some bad bearings. You will at least want to change out the seals and the case half gasket. Let's see what you find...here are the seal and gasket numbers. Axle seals for 1" axles...#100863 this will cross to SKF #9815 Brake shaft seal............#100441 this will cross to SKF #7410 Input shaft seal..............#100442 this will cross to SKF #6105 Case gasket you can get from TORO for about $6...#3912 You can use the thread that Richard put up there for you trans, but you will not have that 10 pinion differential...it is the piece of cake 4 pinion differential. Share this post Link to post Share on other sites
drn441 11 #6 Posted June 26, 2018 Thank you for the info I appreciate it! I measured the axles last night and they are 1" and they were tight up and down and front to back. I'm going to open it up tonight hopefully and see how everything looks inside. 1 Share this post Link to post Share on other sites
stevasaurus 23,662 #7 Posted June 26, 2018 Use this manual Section V for the instructions to open and put back together also. Share this post Link to post Share on other sites
drn441 11 #8 Posted June 28, 2018 I pulled the case apart and it looks like I can get away with just replacing seals and gaskets and cleaning everything up. I took some pictures of my progress. thanks again for all the info 3 Share this post Link to post Share on other sites
stevasaurus 23,662 #9 Posted June 28, 2018 Thank you for the pictures. It does look like just a cleaning and seals. Share this post Link to post Share on other sites
tunahead72 2,627 #10 Posted June 29, 2018 On 6/24/2018 at 6:42 PM, drn441 said: Make sure you replace the gear shift cover while you're at it, it's probably why your fluid was milky in the first place. Toro #3577, $5-$10 lots of places. 1 Share this post Link to post Share on other sites
drn441 11 #11 Posted June 29, 2018 All cleaned up just waiting on parts 1 Share this post Link to post Share on other sites
stevasaurus 23,662 #12 Posted June 29, 2018 That looks great, except...you need to scrape and wire wheel the case halves where the gasket goes. You knew that, didn't you. Share this post Link to post Share on other sites
drn441 11 #13 Posted July 1, 2018 Yeah that's just the picture I snapped after pulling everything from the parts washer before I cleaned the gasket surface. I found the tag on the engine not sure what all can be identified by it.. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,149 #14 Posted July 1, 2018 Kohler made serial 172040634x in 1987 so the engine would land on a 1987 or 1988 model tractor. Engine Specification # 461521 was used in both the 1987 and 1988 310-8 tractor models. Possible tractor models 1987 310-8 tractor model 21-10K804 1988 310-8 tractor model 21-10K805 Garry 1 Share this post Link to post Share on other sites
drn441 11 #15 Posted July 3, 2018 Thank you for the info. I actually have the engine out of the tractor right now because it was burning oil really bad. (I'm thinking it needs rings at least) that should help me in finding a good manual! Share this post Link to post Share on other sites
drn441 11 #16 Posted July 19, 2018 Seals, bearings and gaskets came in and I got it all back together. Everything works and shifts as it should on the bench. I pulled the engine (burning oil) from the tractor and tore it down to find the piston was scored so its at the machine shop getting machined 10 over so I'll have to wait to test it out on the tractor.. Thanks to everyone for the help! 1 Share this post Link to post Share on other sites
