dstriker 2 #1 Posted June 24, 2018 I got this tractor for free so can’t complain it has a 12 hp Kohler on it from what I can see from the tag the model # is k301xx wore off after the 1 any idea what this is and how to keep it running it runs good for maybe half hour then just dies and have to let it sit then will start back up Share this post Link to post Share on other sites
dstriker 2 #2 Posted June 24, 2018 I’m guessing it’s a fuel problem but not sure seemed to loose power after it runs for a little bit Share this post Link to post Share on other sites
953 nut 63,922 #3 Posted June 25, 2018 If the vent in your fuel cap is plugged the fuel pump removing fuel from the tank will create a slight vacuum that the fuel pump is not strong enough to overcome. Share this post Link to post Share on other sites
dstriker 2 #4 Posted June 25, 2018 That appears to be open it also seemed to run longer when I filled the tank completely full of fuel Share this post Link to post Share on other sites
953 nut 63,922 #5 Posted June 25, 2018 1 hour ago, dstriker said: appears to be open I had the same problem years back on a 312-8 and it turned out to be the fuel cap, Try it with the tank not quite full and the cap on but not tight so it will ventilate but not splash out. Share this post Link to post Share on other sites
moe1965 774 #6 Posted June 25, 2018 I had a similar issue and it turned out to be the mechanical fuel pump. I switched it over to a eletric fuel pump and have not had any further issues Share this post Link to post Share on other sites
dstriker 2 #7 Posted June 25, 2018 Ok will try that tonight and see. Thanks for the help Share this post Link to post Share on other sites
