Ephillips2582 6 #1 Posted June 21, 2018 Hi folks! I’m a brand spanking new wheel horse owner. My family and I just moved to Tennessee from Florida. We’ve got 6 acres, and didn’t have a mower for the 2 acres of yard. I happened across an old wheel horse at, what I felt, was a good deal. She’s not pretty. But I prefer older stuff, just easier to work on. As the old saying goes “they don’t make them like they used to”. She was a little rough starting, but ran like a top for the couple of hours I was running her. So yesterday I pulled the battery, starter and relay. Have a new battery and relay, and having the starter rebuilt locally. The problem I have encountered is that I don’t know the model or year. I can’t find a badge anywhere on her. I’ve looked exterior and all over the motor. All I can tell you is it has a Kohler twin 17. Pictures below of the rest of her. Any and all help would be greatly appreciated. 3 Share this post Link to post Share on other sites
Sparky-(Admin) 26,295 #2 Posted June 21, 2018 What you have is a C-175 automatic. Made from 1980 to 1984. Does the tranny fluid filter point towards the rear or the side of the tranny? That will narrow down the year a bit..to the side is an early 1980 and to the rear is a late 1980-1984. Is the model# tag still attached under the dash? Close to the hydro lift lever? 1 Share this post Link to post Share on other sites
midpack 1,148 #3 Posted June 21, 2018 looks like a nice clean series I Kohler in a C-175. mu guess is it's a Sundstrand hydro (can't see the filter in the back end shot) looks like you could use a muffler too Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,590 #4 Posted June 21, 2018 C-175, not sure of the year, cant see rear good. Its a fine machine. Like mine. BTW. . . Glenn Share this post Link to post Share on other sites
Ephillips2582 6 #5 Posted June 22, 2018 Excellent! Thanks all of you for your input. -I did not see a badge under the dash. -It has a muffler. That pic was post disassembly for the starter. So it was already taken off. -does the pic below help? 1 Share this post Link to post Share on other sites
953 nut 69,117 #6 Posted June 23, 2018 1980 was the first year the C-175 had an Eaton Trans. Need the model number from the tag. Share this post Link to post Share on other sites
peter lena 10,046 #7 Posted June 23, 2018 welcome and thanks for the pictures, just a heads up on that starter, found using " fluid film " on the starter drive twist and the drive gear itself makes for a very fast and smooth starter, the gear lube will eventually get to all the flywheel teeth, and you will notice a smooth and quick spin up on your new starter, pete Share this post Link to post Share on other sites
midpack 1,148 #8 Posted June 23, 2018 20 hours ago, Ephillips2582 said: Excellent! Thanks all of you for your input. -I did not see a badge under the dash. -It has a muffler. That pic was post disassembly for the starter. So it was already taken off. -does the pic below help? Looks like an Eaton hydro. Could be a later C-175. You could try to hone in on the year with the engine tag. Looks like an original series I Kohler Share this post Link to post Share on other sites
Ephillips2582 6 #9 Posted June 26, 2018 Awesome input from all. Got the starter back today. I’ll be looking for fluid film now. Then assembly and see how she goes. Share this post Link to post Share on other sites
