RubyCon1 63 #1 Posted June 21, 2018 Is the drive idler "L" bracket on the idler arm and shaft assy (wh7449) supposed to be welded to the assy or is supposed to be adjustable and held in place by the idler pulley bolt? This is the small bracket used to pinch the drive belt in the clutched position. Thanks in advance. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,006 #2 Posted June 21, 2018 I think the bolt is all that holds it. I try to adjust so it does not pinch the belt with the clutch applied. It allows the gears to be selected easier when the belt can move. Garry 1 Share this post Link to post Share on other sites
